Truck down on power, icp drops off the cliff at WOT
#61
Now something else I tried with some interesting results. Udsuth78 recommend I unplug my injectors and monitor ICP under an extended crank. He also gave me the great idea of using my old ebpv connector as a test lead for energizing the IPR straight to the battery. The results are as follows.....plugged in 2300psi. Energized with test lead 1700 psi. Not sure what to make of that.
The following users liked this post:
#62
I was going back through everything just for giggles, and found this little head scratcher and think I have a plausible explanation for the lower ICP while hooked direct to battery. Battery voltage, on a long crank between the glow plugs and the starter pulling hard on the batteries I often see voltage drop down as low as 10.7-11.3. Loosing 2v in a 12v system will definitely make a difference in out put from any and all of the electronics. Of course no way to know if it's true but sounds good anyhow. So I can sleep easier now at least.
#63
#64
#65
You have a point. While I'm not 100% certain as I don't have a physical gauge to tap into the oil rails with nor did I try a different sensor but I gotta assume it's reading pretty accurate because with the new pump it's giving me perfect readings for a healthy HPO system. I suppose it could be glitchy and that might also be an explanation for why it was reading 2300 psi with the IPR plugged into the trucks harness and 1700 psi with it hot wired straight to the battery
#66
What really makes me scratch my head is what would make a pump able to build great pressure but not volume? I mean its just a bunch of little pistons or plungers moving up and down on a swash plate. It was obviously capable of building 3000#+ of pressure based on my posted live data graphing but what component or set of components inside would make it drop off so bad under high IPR command?
#67
jdmarshall
24
01-22-2020 05:52 AM
20powerstroke02
07-25-2016 07:23 PM
lemonshindig
24
05-14-2014 08:29 AM
1'stonraceday
04-06-2014 05:46 PM
JonathanN
07-19-2010 06:05 PM
