2005 v10 engine
And 2-how deep pockets do I need to repair what is there and what would be the recommended course of action if I was to fix it? I’m fairly handy but this might be a bit much for me.
It'll ultimately cost more than you think and be more work than you think and at the end of the day you're stuck with the wheezing 3V V10 which is a horrible truck motor (I ran an '08 all over Colorado until it dropped a valve).
If you want to go minimum investment and flip it as a running truck, maybe. If *I* wanted it for myself, no way. I'd dump it off/part it out and look for a slow-but-reliable 2V or a 2011+ 6.2
If you want it for yourself you should do full timing set (you'll likely find pieces of guide in the pan anyway), HV oil pump and all roller followers both heads.
Or, there's always a Cummins swap!!!!
Maybe you had a lemon so quit spreading internet lies, please. You are doing a disfavor to this site and anyone who reads it.
