Sponsored by: Real Truck
Cruise Control Fixed
Old May 23, 2023 | 07:44 PM
storminc's Avatar
storminc
All the posts I could find were pretty old. I thought I would offer up how I fixed my Cruise Control. 2003 F250 CC 7.3 Lariat Auto Transmission
I got my truck back from the Stealership to repair a no crank no start. They sorta fixed it. I finished their job.
I then noticed my Horn and Cruise Control not working. So I decided to replace the clock spring. I was installing a reconditioned Steering Column so really no extra work.
Finished up. Still no Horn/CC.
I started checking fuses like I should have in the beginning. Shazam. The Stealership had pulled the horn fuse idk why. Replaced same. Honk honk.
On to CC. Posts suggested to check new fuses on factory recall for the Brake Pressure Switch harness. I found two weather proof taped up and wire tied fuse holders. Opened them up and what a mess. Both were very corroded . It was almost as if battery acid had gotten into the holders. I even had trouble getting the 2 Amp fuses out. Both were blown.
Cleaned everything up brushed the fuse holders and used Contact Cleaner on them. Replaced fuses. Buttoned everything up extra protected with dielectric grease on outside of holders, tape and wire ties.
Test drive and works as intended.
So if inclined to track down a no Cruise Control problem, give this a try. I hope this helps somebody.
Old May 23, 2023 | 08:36 PM
storminc's Avatar
storminc
Newbie
Hi. Norman Croy from Blacksburg, VA. My stable has 3 Bronco's 81, 90, 95. 07 Exploder, 90 F150 and the Second best (95 is 1st) a 2003 F250 Crew Cab Lariat 7.3.
The 90 Bronco just needs a fuel pump. Interior, Red, in New Condition. 95 Bronco Blue and Tan is awaiting Caboff restore. 81 is a 300cid 4 speed. Has some floor rust etc. Engine may have 300 miles or less since rebuild.
07 Exploder needs Transmission work. 90 F150 was my Dads Truck.
So that's my vehicles. I'm a Retired Sheriff's Lt. Of 30 years. Volunteer FD 42 years. VAARNG 11B inactive. 5 boys from 34 to 22. Three Grandchildren. My ex is one of my best friends. My mom is still alive at 92 years young.
Salute Folks
regidog
Mar 9, 2010 10:10 PM
1988midnightblue
Jun 22, 2007 07:24 AM
John311t
Jan 19, 2007 06:54 PM
4.0 Beast
Oct 30, 2003 06:25 PM
4x4_EB_Explorer
Electrical Systems/Wiring
Apr 19, 2002 10:27 AM
