Sound check
Old May 18, 2023 | 06:04 AM
MuttHowls's Avatar
MuttHowls
4wd Low
Sound check
Start at 17 minutes and let me know if you all think this setup would sound similar to an 8 cylinder after running the exhaust to the stock location.
Thank you,
Mutt
Old May 18, 2023 | 06:05 PM
DaveMcLain's Avatar
DaveMcLain
Unless you really muffle the exhaust to an extreme amount it'll still have that 6 cylinder sound. Keep in mind too that the fewer the number of cylinders the tougher it is to effectively muffle the exhaust. A typical 90 degree V8 is a rather unique situation when it comes to exhaust in that each side of the engine has 2 cylinders that fire only 90 degrees apart and thus overlap. The exhaust sounds and behaves sort of like a V6 with two larger cylinders, one on each side.
Compare the sound of the engine in these two videos of engines that I'm running on the dyno, both are Cleveland engines for Pantera applications, the 384 cubic inch one uses a conventional 4 into 1 Pantera header with a 2.5 inch outlet pipe. The other one which is 406 cubic inches uses a beautiful set of stainless steel 180 degree headers where two pipes cross over from each side making each collector act as though it was connected to a 4 cylinder engine. Both engines are making around 620 horsepower and turning to about 7000rpm.
Gary Lewis
2015 - 2020 F150
17
Jan 4, 2016 12:24 PM
83maverickf-100
Apr 15, 2008 09:14 PM
f100guy
Apr 18, 2007 11:31 PM
MattsBigf150
Exhaust Systems
42
Feb 23, 2004 12:55 PM
