Engine running rough. Timing?
Old May 18, 2023 | 09:41 PM
96150's Avatar
96150
Thank goodness. Okay I’ve removed two of the bolts holding it to the engine and I’ll do the rest tomorrow. Any other input on the lack of power? I mean the engine has ticked since I bought it but it became really bad just recently. My theory, and maybe this is far out there, but it happened after I took it on the highway for the first time. Perhaps the higher rpms and heat/pressure had an especially greater toll on the existing crack? Sounds a bit far fetched but who knows. Thanks for all you guys’ help, this forum is great.
Old May 19, 2023 | 12:35 AM
Ronniewhite's Avatar
Ronniewhite
Originally Posted by 96150
Update: I just tested my exhaust by hooking it up to a leaf blower and I did indeed find cracks. I am going to pull and inspect both and then maybe do a pressure test after I reweld them. I’ll keep you guys posted! Thanks!
how do you do this?
Old May 19, 2023 | 02:15 AM
Prototypemech's Avatar
Prototypemech
Start with the basics:
Check your compression.
Check your fuel pressure.
Check for codes.
Check your timing.
Old May 19, 2023 | 05:56 AM
Mudsport96's Avatar
Mudsport96
Time the engine after reinstalling lifters? I didn’t know I even had to do such a thing (although I should note that the ticking was present before and after the lifters were replaced. Also not sure if this is relevant but it is definitely lacking power (won’t go above about 20mph)
This is probably your main lack of power. The engine needs timed correctly and run before any proper diagnosis can be completed
Old May 19, 2023 | 02:18 PM
knottyrope's Avatar
knottyrope
if your timing is fluctuating that much and you have unexplained ticking noise, the Harmonic balancer can do that when it fails and Heat will make them worse as the outer ring expands and the rubber detaches from it
at idle look at the crank pulley for any wiggle to it
Old May 21, 2023 | 10:33 AM
96150's Avatar
96150
Okay so a little update. I have pulled the manifolds both upper and lower intake as well as the exhaust. While I am almost positive I felt air escaping from the exhaust manifolds while they were on I see no cracks right now. Is there a good setup for testing them? It could be a hairline crack that I just can’t see because of rust and such. I put them in an electrolysis bath for a few hours to clear some grease and rust off. Unfortunately the ear of the lower intake manifold by cyl 6 broke off while I was removing the exhaust so I will need to buy another one. I’ll look into harmonic balancer as well as timing stuff but it will be some time before I get an intake manifold in. Anything I can check in the meantime that hasn’t already been said?
Old May 21, 2023 | 11:22 AM
rla2005's Avatar
rla2005
Lay a long straight edge across the exhaust manifold ports to check for warping. Look for pitting at the ball and socket flanges.
If you need to replace the harmonic balancer be sure to get one with the tone wheel for the misfire detector. 1996 only part. Consider sending yours out for rebuild.
Old May 23, 2023 | 06:04 PM
96150's Avatar
96150
Okay sorry for the delay. Update. Both manifolds have been pulled have been inspected for hi and low areas. The gasket itself seems to be okay with maybe a couple of sooty areas. I’m going to upload some pics of the manifolds and also the gasket. (My apologies I don’t have a photo of the manifold for cyl 4-6 but I will take one today).
gary's1950F1
Sep 15, 2018 08:25 PM
Matt1968
Oct 12, 2017 11:16 AM
Rod Beauvex
Feb 24, 2014 07:40 PM
DoofusOfTheDay
24
Sep 10, 2013 11:40 AM
cnadaddy
1978 - 1996 Big Bronco
Aug 28, 2004 11:25 PM
