Fluid check
Old May 15, 2023 | 10:58 AM
power15's Avatar
power15
Fluid check
Hi,
my 2015 powerstroke has about 55,000 miles on it, the check fluid additive light comes on, is this a mileage or date alert or does it really check it? I have around 500 miles till the next oil change, can I wait to have it checked then?
Thanks
Old May 15, 2023 | 11:15 AM
wp6529's Avatar
wp6529
The "Check coolant additive" is a mileage based reminder I believe. It can wait a bit until you check, and if you want to check it yourself you will need to order a test kit from Accu-Ckeck which is/was about $60 for 10 tests but might be a bit more these days. Depending on the results of the test either the coolant is fine or you need to add a bottle of coolant additive to refresh the coolant. The second time it fails the test you have to change the coolant.
Old May 15, 2023 | 09:58 PM
power15's Avatar
power15
Thanks for the help.
Old May 15, 2023 | 10:17 PM
senix's Avatar
senix
just mileage based, just clear the message and check when convient
pilotshot
6.4L Power Stroke Diesel
40
Jul 21, 2018 10:30 AM
slownsy
Sep 25, 2016 05:13 PM
W7PSK
6.7L Power Stroke Diesel
73
Nov 21, 2015 02:49 PM
WH 6.0
Sep 17, 2010 02:38 PM
