Core support removal?
Old May 13, 2023 | 11:28 AM
Hit Man X's Avatar
Hit Man X
Any tips to pull?
Found a nice, square unit in the junkyard I plan to grab today or tomorrow.
Thanks
Old May 14, 2023 | 03:41 PM
fordman67's Avatar
fordman67
I would spray the bumper nuts down with Luby duby.
Getting the stone guard off is easier with bumper off.
Old May 14, 2023 | 03:56 PM
Hit Man X's Avatar
Hit Man X
Keep you guys posted. Should come apart easy as in AZ.
Old May 15, 2023 | 09:10 AM
BuddyBarnes's Avatar
BuddyBarnes
If your core mounts are not in good shape , get new ones . I also needed new washers and bolts for the mounts Slick as you are , you know all this.
Old May 17, 2023 | 07:17 PM
Hit Man X's Avatar
Hit Man X
Still working on it, so many fasteners. Forgot the 8mm had to bum one from a kid there.
Mounts off so that is a plus.
Old May 19, 2023 | 10:33 AM
BuddyBarnes
Have ya learned any new curse words that you did not know?
Old May 20, 2023 | 07:19 AM
Yeoman's Avatar
Yeoman
Thumbs up Core Support Removal
I recently removed my 7.3 radiator core support from my 97 F350.
Removal isn't a hard job by itself. Unexpected discoveries along the way can become separate projects. For example, I removed battery supports and other internal components to recondition them while everything was wide open.
Key to your success will be to take pictures, before and after, of everything you touch.
Baggies and labels where you put nuts, bolts, clips or anything else your remove. One baggie per component, label the bag, store with the component.
Do not disturb the AC coil. Protect it on both sides and suspend its weight so you don't damage the lines. Don't damage or stress it while removing the core!!!
Choose an OEM replacement radiator core if you can. Take the time to clean it up, inspect for fatigue cracks, weld seams up tight, use flexible seam seal to stop water penetration between tack welded parts, prime with two part primer and two part paint. If you go aftermarket, my research found the LMC truck aftermarket support is not bad for the price. (See video link below and no they don't pay me). It is vital to check the height and width dimensions of the replacement core upon arrival. Be sure the fender / hood gap lines will align after reassembly. If the size doesn't match the OEM unit you removed, send it back.
My original core support is being reconditioned because in New England there is no such thing as a rust free core support. Cost to get an OEM replacement from the Southwest region was ridiculously expensive and then those I looked at needed refurbishing.
Good luck!
Old May 20, 2023 | 11:25 AM
Hit Man X's Avatar
Hit Man X
Finally. Phew.
Old May 20, 2023 | 11:30 AM
farmert's Avatar
farmert
Looks like it is oily enough to survive the rust belt, if you were there. Good find.
Old May 20, 2023 | 12:00 PM
Hit Man X's Avatar
Hit Man X
AZ! But yes, super greazy.
Ran out of time going to UT otherwise I would have grabbed mounts. Ha.
68_f100
Jan 16, 2023 06:16 PM
57 t-bird
Sep 21, 2011 12:50 PM
buckshot11
1997 - 2003 F150
Aug 30, 2009 08:47 PM
BigEarlW
Jan 15, 2003 06:55 AM
