Ball joint hoopla
Old May 13, 2023 | 08:44 AM
gammatino's Avatar
gammatino
Ball joint hoopla
I have a 92 f250 4x4. Gvw 8600....The sticker on the door says 3559 for the front axle. But it has a. Dana 50 ttb. After talking to Moog I ordered for the 4500 lb axle and u joint
When searching for parts some of the listings ask about the gear ratio. Re with or without 410 gears.
Mine is 355 I think.I ordered them .Hope there right
Moog 231 joint .. outside clips
Moog k80026
Moog k8435
I did the passenger side like 10 years ago.One thing I caught on this side was to make
sure to clear the drain hole to the left bottom of the lower ball joint.Mine was packed with dirt.Took like 15 minutes to get the dirt cleared out
Can any body guess the decade of that floor jack?
Old Aug 30, 2024 | 12:12 PM
samuel4wolfpack's Avatar
samuel4wolfpack
In early May of 2024, I bought a 1996 F250 4x4 with the 5.8 and zf5, 3.55 rear gears and dana 50 axle. The truck door tag has the same numbers as yours, the 3559 lb front axle and the GVWR of 8600 lbs.
sunbelt57
Aug 11, 2020 04:43 AM
markmarkmark
Sep 10, 2018 05:18 PM
gmammakn
Jul 6, 2018 04:27 PM
abranz
Dec 26, 2016 12:51 AM
norfolknova
Jun 17, 2012 07:14 PM
