I have a 75 F250 with a Dana 60 rear end, I want to replace rear brake shoes, and I am being asked what size I need , I believe I was asked if they are 2" or 2.5", I only have access to a lift for about 2-3 hrs, so I want to have everything I need prior to taking them apart .
Best advice I can give you is buy both and take the ones you don't use back.
Should be 2.5" wide on the Highboy. Fronts were typically 2". There could have been a variation with a light GVW and they were only 2" but maybe someone can confirm. I always thought all Highboys were 2.5
Rockauto.com is a good source for part options and for general pricing.
You don't have to buy from them but they do list multiple options for your parts needs.
Tbruz
my 75 f250 has 2.5 wide ones. i typically do what tbruz says with using rockauto for parts numbers then look them up on amazon,napa,autozone,... not that you asked, but i had a hard time finding hub seals as some part numbers referenced parts with different widths. national 4250's ended up fitting correctly
1973/76 F250 2WD could have 12 1/8" x 2" or 12" x 2 1/2" rear brakes, as it depends on what the Gross Vehicle Weight Rating is.
1977/79 F250 2WD have 12" x 2 1/2" rear brakes.
1966/79 F250 4WD have 12" x 2 1/2" rear brakes.
The front bearings and bearing cups have a BIN stamped on them. These are Bearing Industry Numbers that auto parts stores and bearing shop use.
