rear brake effect
Old May 11, 2020 | 11:31 AM
beartracks's Avatar
beartracks
rear brake effect
I was wondering if my rear brakes were working well so I applied the emergency brake to see and didn't get much slow down at all. Would this be normal? Maybe the mechancical brake doesn't apply as much force?
Old May 11, 2020 | 11:36 AM
flowney's Avatar
flowney
You'll need to check to see if your eBrake linkage is adjusted properly before drawing any conclusions. The adjuster is just to the rear of the cab and is reached by getting under the truck. The cables can get pretty slack over time.
Old May 11, 2020 | 12:17 PM
dlburch's Avatar
dlburch
and ensure the rear brake shoes them selves are adjusted correctly. And if your feeling ambitious, you can pull the drums and make sure the primary and secondary brake shoes are in the correct orientation...the shoe with the most friction material should always be the rear shoe.
But otherwise, using just the emergency brake for stopping will be MUCH less effective than when the front disks are involved.
Old May 11, 2020 | 12:58 PM
beartracks's Avatar
beartracks
I guess the question is.......... if the emergency pedal doesn't go to the floor should it lock the rear shoes at slow speeds?
Old May 11, 2020 | 01:53 PM
John89's Avatar
John89
If you are just wanting to check the parking brake, park on a hill with a decent grade, put parking brake on and put transmission in neutral. Parking brakes should hold if working.
Now for overall rear brake function, I would pull the drums and inspect. The shoes could be out of adjustment.
Old May 11, 2020 | 02:39 PM
kwe45919's Avatar
kwe45919
Maybe not lock the rear up but it should slow it to a stop and be able to hold the truck when parked.
Emergency brake isn't just for parking on hills....they are supposed to be a working manual brake you can apply if needed in an emergency....and with that, it the rear was to lock up, then your vehicle is out of control so what would be the purpose of attempting to use it if you were already out of control?? Hope that makes sense...
Old May 11, 2020 | 05:14 PM
5851a's Avatar
5851a
I don't believe Ford ever calls them emergency brakes, only parking brakes. Not sure what year it started but mfg. had to supply the braking information on vehicles. It would show the 4 wheel stopping distance, then a partial system failure distance and then total hydraulic failure and only parking brake. I think Fred Flintstone could stop in a shorter distance than just a parking brake.
Old May 11, 2020 | 06:19 PM
meangreen92's Avatar
meangreen92
You can get a better engagement of the parking brake by applying the brakes as you stop the truck, and then engaging the parking brake before lifting off of the service brake pedal.
Old May 11, 2020 | 09:49 PM
JacobJ's Avatar
JacobJ
Just put the rear axle on jack stands and give it gas and brakes at the same time. But more importantly- when in doubt about the condition or age of your brakes don't take any chances, replaces all that stuff.
Old May 12, 2020 | 08:26 AM
kwe45919's Avatar
kwe45919
Originally Posted by 5851a
I don't believe Ford ever calls them emergency brakes, only parking brakes. .
Call it what you want when ya use it.......it's my emergency manual braking system if all else fails while driving and my parking brake when on hills.
Old May 12, 2020 | 10:02 AM
beartracks's Avatar
beartracks
Well I guess it will be a good excuse to go out and stomp on the brakes at about 40mph and see if I get 4 tracks.
Old May 12, 2020 | 12:03 PM
Tedster9's Avatar
Tedster9
The "automatic adjusters" don't, after some time & corrosion. A little attention to the rear brakes helps quite a bit. Most of the stopping power ~70% is from the front axle so the rears get ignored, but every bit helps. Adjust them manually at least, so there is a light drag on the drums when spinning the wheel.
Old May 13, 2020 | 01:40 AM
1TonBasecamp's Avatar
1TonBasecamp
What size tires do you have beartracks? Bigger tires could give the parking brakes a real run for their money.
Were there different size brakes for F100's? Like large and small? If so, maybe you've got the small ones and that would add yet another level of possible weakness with larger tires.
Paul
Old May 13, 2020 | 09:03 AM
beartracks's Avatar
beartracks
Rears are 255 r60 15. I agree with the adjusters not working too well, even with new everything. I've had good luck with EBC brake products lately. Trucks stops very well, just wonder if I'm getting everything I can outta the back.
Old May 13, 2020 | 10:31 AM
Lrrr-RulerOfOmicronP's Avatar
Your parking brake should keep the truck from moving while engaged with a stock hp motor. If not it needs adjusted property or is in need of new parts.
