Fuel pump relay
Old May 8, 2023 | 10:34 PM
aanorm036's Avatar
aanorm036
Trailering
Fuel pump relay
Recently tried changing my fuel pump relay (believe its the one closest to the driver side fender in fuse panel under the hood?) because the terminals looked rough and it seemed to be getting hot which suggests to me the contact inside the relay isnt closing properly and generating an arc. Anyways I changed the relay out and noticed my fuel pumps didn't prime when I turned the ignition and the engine wouldn't start. So obviously the new relay doesn't work properly but the circuit diagram on both are identical. Could I possibly have a short somewhere or is this a common issue any of you have dealt with before? Any help is appreciated
Old May 9, 2023 | 01:14 PM
rla2005's Avatar
rla2005
What year, model, engine truck are you working on?
Old May 9, 2023 | 03:13 PM
aanorm036's Avatar
aanorm036
Trailering
Sorry forgot to include that.
Truck is a 1996 F250 with a 5.8L
Old May 9, 2023 | 03:59 PM
camper357's Avatar
camper357
fuel pump relay
I would test the relay with a multimeter and a 12v battery to see if the replacement relay is any good.
Old May 9, 2023 | 04:23 PM
rla2005's Avatar
rla2005
Which relay did you replace?
Old May 9, 2023 | 05:46 PM
Prototypemech's Avatar
Prototypemech
Check the terminals inside the power distribution box. Its 27 year old plastic and sometimes the plastic terminal retainer breaks when disturbed. When you try to install the new relay, the terminal slides to the bottom of the box and doesnt make contact.
aanorm036's Avatar
aanorm036
Trailering
according to your diagram it would've been pcm power relay but when I pulled that relay and turned the ignition I couldn't hear the pump priming and with the relay back in place I could hear it prime
Old May 9, 2023 | 07:47 PM
rla2005's Avatar
rla2005
With no power to the PCM the fuel pump relay is never energized.
The diagram I posted is for a 1996 F-series truck with a gas engine.
Old May 9, 2023 | 11:07 PM
aanorm036's Avatar
aanorm036
Trailering
that would make sense. Probably should have tried to find a diagram before i did my self test lol. I'll try it in the other relay slot tomorrow and see what happens.
Old May 10, 2023 | 10:22 PM
solanum's Avatar
solanum
My $ is on what Prototype said. I've seen it happen many times.
evaleriano
Nov 17, 2021 10:21 AM
RedTaurus94
1983 - 2012 Ranger & B-Series
Aug 13, 2015 06:44 PM
bleevan
Aug 22, 2007 03:06 AM
chrono4
General Automotive Discussion
Aug 7, 2007 01:19 AM
Avanti
Bronco II
Sep 8, 2002 11:13 AM
