7.3 idi broke down
Two things set the check engine light on these trucks, no oil pressure, or overheated. There are three water temp sensors on the engine. One runs the cold idle solenoid and timing advance solenoid, its on the front of the passenger head. The other two are in the drivers head, but I don't remember exactly where each is. One is for the gauge, the second is just an on/off switch that pegs the gauge on hot and triggers the check engine light if the engine gets too warm. That switch sensor is known to fail in the tripped (hot) position and might be what is causing your check engine light to stay on. Might be possible that the previous owner swapped the wires to the two sensors, I'm not sure if thats possible and what would happen. A couple things for you to check. Right now I'm having a brain fart if there is a separate coolant hot warning light, or just the one check engine light? But yah you'll want to get that fixed. If the gauge doesn't work after testing out the sensors, get an aftermarket gauge, having some understanding of actual engine temp is crucial. Could be a lot of reasons it might be overheating. Also it is normal for some coolant to end up in the overflow tank. If its pushing out of the overflow tank, thats a problem.
I'm not sure I'd trust a pillowcase over a filter. I guess some pillow covers are supposed to be a certain size to keep out dust mites, not sure what you are using...
Lift pump isn't too bad to do, easy to get to from underneath. Think I had someone holding it from above while I bolted it in from below. Not sure it was needed, but he was hanging out in the garage anyway. Probably worth swapping out the loop of hose that runs to it. You want to keep that as a loop to keep the hard line from vibrating as the engine runs.
Does your Mother, Girl Friend or Wife know you are using her pillow Cases?
How are you washing them, in your Maytag?
Throwing them into the land Fill?
Why don`t you go back to burning Diesel instead of UEO.
Fix, repair all the little problems and get it to operate on Diesel,
what it was originally built to run on from the factory.
Make sure the fuel system is air tight, not sucking in air some place,
that will for sure shut you down, which may be your problem when
stopping at a red light.
Replace the Lift Pump if you see it leaking or your oil level is increasing.
Replace the Vacuum Pump if it is not working.
No vacuum = almost no Brakes. Been there, when you are giving the peddle
all you have, and the truck isn`t slowing down as fast as it should, and your
closing speed is rapidly approaching, the Pucker Syndrome will be puckering
in the whole Bench Seat....Been there...done that.
Get a Lazer Heat Gun pointer thing to see exactly what the Engine/Radiator
temps really are. Don`t rely on the Dash Gauge.
You can`t guess your way to fixing your Engine.
https://www.harborfreight.com/automo...ter-63985.html
Your truck did not Break down, I just failed to move forward.
Goat
I am not too worried about the wmo being filtered with the pillow case. I have heard of multiple people using 10 micron filters, the pillowcase is atleast 10 microns if not less. The fuel line looks to have already been replaced so I don’t think I’m going to replace it. I swapped to my tank of diesel but the lines are filled with wmo already so it won’t change anything for a while. I tried to start it after charging the battery’s overnight on my trickle charger but it still was cranking slow. I’m going to charge them fully and try again. I also think I am just going to remove thermostat for now. It is hot enough where I live that it doesn’t need it.
Honestly I am surprised by how good the brakes are without the vacuum pump. they are hard but still stop well. I am going to try a new belt once I get it running and hopefully that fixes it but worse case I just go to a hydro boost system.
I am going to get a lift pump tomorrow, am I good to just get one from autozone or orilleys?
also should I be concerned about the slow cranking? It doesn’t sound like it’s galloping or making any weird noises but it’s just concerning because it usually cranks faster. Is there any tests I can do see if there is a issue internally?
a bad starter can not turn the engine fast enough to fire off.
you should not crank the engine more than 30-45 seconds, than let it sit for at least two minutes to cool off.
it is very easy to overheat and burn these starters up.
I am going to get it running with the new pump before I do the thermostat, but when I do it I will definitely use oem. I will install the new pump tomorrow and probably try to bump start it, then get the starter installed.
unlike auto store parts that go to a giant rebuilder that replaces what is bad and call it good enough. they don't care because no one will ever know who "rebuilt" it.
Brand new, and American made.
Been using mine a good 4 years. Search for a good price, saw them
on E-bay for $197, up to - $250 depending on what retailer is selling them.
I was searching about 6 weeks ago and found a return for $149 and free
shipping from Speed Way Motors. Was a return and in the original
packaging.
I haven`t seen a rebuild shop in like forever.
Charlie
