AOD troubleshoot.
Old May 7, 2023 | 02:45 PM
Richard Mechling's Avatar
Richard Mechling
AOD troubleshoot.
Have a 1986 Ford F250 With AOD 302 EFI 2 wheel drive 8ft bed base model with over 100.000 miles Begin to experience a shudder when going into 3rd gear only every other gear including overdrive no problem and no problem until the truck is driven for a while. And transmission is warmed up. Then there's When I experience the shutter. With no noises. Check the transmission fluid Brown and slight burnt smell. Checked Throttle valve cable working And right position. Did not check with a pressure gauge internal pressure. drop the transmission Pan Drain the fluid including torque converter check valve body bolts with inch pound torque Wrench to specs. Noticed some glitter in the Pan and dirt also from a dirty funnel. Run a magnet in the Pan picked up tiny shaven's Sticking to the magnet. But not much. Refill transmission shifts and runs great until it's hot and still have the 3rd gear shutter but not as bad and only when hot. Check temperature around transmission. Couldn't find it no more than around 128 f.
Old May 7, 2023 | 03:25 PM
Franklin2's Avatar
Franklin2
Put this stuff in it. It's not cheap but if anything will get rid of the torque converter clutch slipping, this will do it. I have personally seen this stuff work.
https://lucasoil.com/products/proble...ansmission-fix
Old May 7, 2023 | 05:27 PM
Richard Mechling
Thanks for your advice but I am also wondering about changing the torque converter because I would like to permanently solve this issue so have you ever seen a shudder problem that wasn't the torque converter and was some other transmission issue.
Old May 7, 2023 | 06:47 PM
Conanski's Avatar
Conanski
There is no clutch in an AOD torque converter so if you were thinking the chatter was the TC clutch then you should know that isn't a possiblity.
Old May 7, 2023 | 08:09 PM
Richard Mechling
OK thank you for your reply.
Old May 8, 2023 | 12:43 PM
Richard Mechling
Well after hashing all this out with AOD decided to rip it out of there get a good quality transmission rebuild kit and torque converter. Break it down. Rebuild it back and Post my results after completion. I may break it all down 1st before I order parts kit just so I get everything that I need at once.
Old May 8, 2023 | 02:28 PM
Max Capacity's Avatar
Max Capacity
Please take pictures so we can learn too.
Old May 8, 2023 | 04:49 PM
Richard Mechling
Yes good point about the pictures. I will take them as a reference to step-by-step so that I could remember Disassembly.
Cobra-Kai
69
Dec 21, 2013 10:28 PM
Oscon
Sep 23, 2013 06:42 PM
THE BLUE HEAP
Mar 29, 2011 05:48 PM
895.0f-150
Apr 10, 2010 02:22 PM
Cor
Mar 2, 2006 09:58 PM
