What engine stands do i need to put a 460 in a 79 f250 4x4 with a 351M? I know these trucks came with a 460, but very scarce in junkyards in this area. 460 engine is in a 86 f250. Thanks
460 was not available with a manual trans or 4WD until 1983, and these F250/350's thru 1997 used a hydraulic clutch.
As reported…. you won’t find factory 460 mounts because they weren’t installed in 4wd until later. However, your trans and the frame mounts are the ones that you need. Order a set of 460 swap insulators, aka rubber mounts. Google is really gonna be your friend on this one, a very popular swap that’s been around since the 429/460 was born.
Thanks guys for the responses. Yes, the 86 is a f250 4x4 4speed. Not sure of direction i will go. Really want to do up the 79 because of dana 60/411/ limited slip, but the 86 in much better shape, ac all intact, etc. Got a ways to go before i have to decide.
