2001 Edge headlights
Old Nov 17, 2003 | 07:58 PM
2001yellowEdge's Avatar
2001yellowEdge
I just got some Silverstar lights, and noticed what a pain in the *** it is to install them. I have pretty big hands and cant exactly reach in there. Do I need to remove the battery or any screws to get to them?
Old Nov 17, 2003 | 08:15 PM
Dealford's Avatar
Dealford
Welcome to FTE 2001yellowedge. If you've got bear paws for hands, then you'll have to take as much of the truck apart as needed to make a hole big enough for them to fit.
Plan-B... Get a buddy with small hands to help you. The battery may still be in the way some.
Old Nov 17, 2003 | 08:44 PM
2001yellowEdge
haha, thanks. Thats kind of what I didn't want to hear. Can you just push the clip in and pull the bulb out, or do you have to unscrew that holder while it is still in place?
Old Nov 17, 2003 | 08:53 PM
surelly09's Avatar
surelly09
ummmm dude..... you have to remove the headlight assembly. This procedure is explained in your OWNERS MANUAL. Or this can be accomplished by First removing the to small screws that hold a small cover on. Remove this cover. Then behind the headlight assembly are two sliding retainers. they slide UP. Simply slide the headlight assembly out of the front end. Then remove the twist off retainer nut holding the bulb in place.
Old Nov 17, 2003 | 08:57 PM
2001yellowEdge
alright, that makes a little more sense. Thanks
Old Nov 17, 2003 | 08:58 PM
surelly09's Avatar
surelly09
no problem man. If you get lost while yer at yer truck.. just use the owners manual. It says exactly the same thing.
Old Nov 17, 2003 | 09:16 PM
surelly09's Avatar
surelly09
