Cam
Old May 4, 2023 | 08:51 AM
black & blue 78/9's Avatar
black & blue 78/9
Cam
Hi all, I've been looking for a cam blank, or cam stock ( whatever it's called). I have called comp, crane, lunati and cam research. No one has a blank for a 460. All of them told me they will not sell a blank so I can have it ground to my specs. One said to give them the specs and they would do it. What other companies out there can I call to possible find a blank to purchase?
Thanks Chris
Old May 4, 2023 | 06:04 PM
DaveMcLain's Avatar
DaveMcLain
If your old stock core is good the best plan would probably be to just have it reground. Steve Demos can do that but right now I have the master for the 200H lobe so I'd have to send it back to him. Right now I'm just getting started with my cam grinding machine. I've got it all rebuilt, set up and working but I'm still in the process of getting my index plates and masters together.
Old May 5, 2023 | 07:59 PM
black & blue 78/9
The cam specs you were using before the E4OD ungrade, could Steve regrind my original came to those specs? I believe you said your current 200 specs could not be ground into a stock cam. The LSA could not be changed.
Old May 5, 2023 | 08:27 PM
black & blue 78/9
Thread size
What is the bolt size to thread into the cam to make it easier to remove from the block?
Old May 6, 2023 | 07:45 AM
DaveMcLain's Avatar
DaveMcLain
Steve has masters for the Torque Master lobes and those would go onto the stock 460 core no problem. The 205 @ .050 lobe ground as a single pattern would run very well.
The flat tappet cores are all 3/8-16
Old May 8, 2023 | 09:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Want cam cores? I have two EFI ones (well, I haven't pulled the second one yet) I won't use for anything.
Old May 9, 2023 | 01:17 PM
DaveMcLain's Avatar
DaveMcLain
I would be interested in a couple of those cores but the cost of shipping might be too high.
Old May 9, 2023 | 05:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I don't mind shipping them if they'll be put to good use!
Old May 9, 2023 | 10:16 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I got the second cam out tonight. It looks fine even though the #1 and #5 rods wanted fresh air.
Old May 10, 2023 | 06:36 PM
DaveMcLain's Avatar
DaveMcLain
I can assure you that they won't go to waste:
Thank you,
McLains' Automotive
1057 Hwy DD
Cuba MO 65453
Old May 10, 2023 | 07:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'll get em boxed up nicely and ship them either Friday or Monday when I go to town. Hoping to not have to go before then!
Old May 18, 2023 | 05:34 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Finally they are on the way. Interesting packaging....don't call the bomb squad.
Old May 18, 2023 | 05:53 PM
DaveMcLain's Avatar
DaveMcLain
Thank you again for helping me out. I've started the process of getting some masters together to go along with the ones that I already own. A few days ago a customer brought in a brand new HP289 cam that he bought from Ford in 1965. I straightened it and used it to make a master. I probably won't use that one very much but you never know I just might need a moderately small solid lifter lobe.
Old May 18, 2023 | 06:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You've been helping strangers on the internet for nearly 2 decades. Knowledge is power.
I do what I can. Hopefully UPS is nice to the shipment!
Old May 24, 2023 | 07:50 PM
DaveMcLain's Avatar
DaveMcLain
The cams that you sent me arrived today. Hopefully none the less for wear but the packaging sure took a beating... Thanks again.
