RPM increase when Idling
Old May 2, 2023 | 04:01 PM
1011hans's Avatar
1011hans
Trailering
My 2017 super duty diesel started revving while idling today even after warmed up. It acts like is does when extremely cold but it's in the 70s today. Any clues?
Old May 2, 2023 | 04:15 PM
jmntn2000's Avatar
jmntn2000
It could be doing a regen.
Old May 2, 2023 | 04:22 PM
1011hans's Avatar
1011hans
Trailering
I bought this truck new, I've never experienced a regen. It now has 88k miles. I'll look into this...thx for quick response.
Old May 2, 2023 | 04:54 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Have you brought it into the dealership lately... there was an update that they were doing at one time that was causing the truck to idle high when sitting... there was a thread (or 2) on it some time back.
Old May 2, 2023 | 05:36 PM
4wd6.7L's Avatar
4wd6.7L
Let me guess, it goes up to about 1k RPM after it's been idling for a few minutes, if you tap the accelerator or brake it stops but will start again if left idling......in 88k miles you definitely have experienced a regen, you just weren't aware of it. As Chad mentioned, there was a PCM reprogram for emissions purposes that included your year. There have been other owners who said they never experienced this elevated idle before the reprogram. That may be true, what you experienced is now normal, and intentionally programed into the PCM.
I've posted this screen shot in other threads, this is likely what you noticed, and not a full on regen.
Old May 2, 2023 | 05:45 PM
Ford Fx4's Avatar
Ford Fx4
Part of emissions recalls 20E07.
Mine all do it too now.....been to the dealer lately?
wylecoyote's Avatar
wylecoyote
My work truck does that when it goes in to a regen if I am idling for a while. Once the regen stops, it idles back down again. Its a 22 350.
Old May 2, 2023 | 05:48 PM
4wd6.7L's Avatar
4wd6.7L
How are you determining that it is going into a stationary regen at the time?
Old May 2, 2023 | 05:51 PM
wylecoyote's Avatar
wylecoyote
The indescribable smell of the regen process. You know the one, like something is burning.
Old May 2, 2023 | 05:57 PM
4wd6.7L's Avatar
4wd6.7L
The other process (the SSM added to the post above) also smells. These trucks don't typically go into an uncomanded stationary regen is why I asked.
Old May 2, 2023 | 06:04 PM
wylecoyote's Avatar
wylecoyote
Fair enough. I assumed it was going into a regen. But maybe not.
Thank you for the heads up.
Old May 2, 2023 | 07:41 PM
srkr's Avatar
srkr
My 2017 in 118,000 miles never raised idle once. I also knew about the programming and was specific at the dealer to NOT program my truck.
I traded it away so it's for the next person now.
looks like my 2023 I will not have any choice.
Old May 2, 2023 | 08:14 PM
406f150's Avatar
406f150
Ever since the last recall flash my 2017 has odd idle-up cycles. No, it's not in regen when it does it. Sometimes it goes straight to high idle when I remote start it when it's below freezing too. Zero idle, as soon as it fires it goes straight to 1000+ rpm. Not a fan.
Old May 3, 2023 | 07:02 AM
speakerfritz's Avatar
speakerfritz
my 2019 stated doing this 10K miles ago after I took the truck in for a tailgate recall and they decided to also reflash my PCM. there is a another PCM reflash on the list which may or may not fix this bug from the first reflash. BTW, I wasnt advised beforehand about the reflash...they just did it....thinking about a odbc port lock so they wont be able to reflash with out my consent.
Old May 9, 2023 | 06:16 AM
1Bornlzr's Avatar
1Bornlzr
6th Gear
I believe what you're experiencing is not a regen cycle but programming that is identifying outside temps, engine operating temps and idle times and as a result may increase the RPM to prevent wet stacking. Step on the brake or accelerator and it resets the process only to begin the anaysis all over if left to idle.
