seal driver depth
Old May 2, 2023 | 12:45 AM
mauser3's Avatar
mauser3
4wd Low
seal driver depth
I'm going to use an oil filter (1995) to press the seal inside the knuckle. Does anyone have the seal driver 6695 or equivalent to take the depth measurement so i know how far to press it in? Or, how will i know that its in far enough
Old May 2, 2023 | 04:24 AM
udsuth78's Avatar
udsuth78
It will only go as far as the axle shaft will slide into the differential. Can't really go too far, well provided your not forcing anything. Just buff the inside of the knuckle, doesn't have to be shiny just smooth. Oil the seal and the knuckle, (remember everything in life is better w/ the proper amount of lubrication) and it should go in pretty easy once it's started in the bore.
Old May 2, 2023 | 08:06 PM
mauser3's Avatar
mauser3
4wd Low
Thanks udsuth for the info.
Well, it does work but it went in a little to far. Had to back the axle out about an 1/8 to a 1/4 in order to get the c clip in the grove.
A measurement would have nice but it must be a secret.
Old May 2, 2023 | 10:01 PM
udsuth78's Avatar
udsuth78
Of course it works, I'm the one who figured it out, and if over shooting the gasket seat a 1/4 was the most eventful part of the job then you better hoist your glass and give thanks to the truck gods tonight. Best not to tempt their wrath. (Just in case you're unaware, smartass is my middle name. My mom had it legally changed when I was 25.)
I doubt anyone has ever thought or bothered to actually take a measurement. I bet I've had my knuckles apart at least half a dozen times probably more and never thought to myself ”better measure that”.
Old May 3, 2023 | 08:36 PM
JeepGuy93's Avatar
JeepGuy93
I measured 1.280" depth on my 6695 driver tool. I bought the tool just before you posted the oil filter hack.
I'd be damned if that was purposefully orchestrated by the Ford/International/Dana engineers. It's almost too good to be dumb luck.
Old May 3, 2023 | 10:23 PM
udsuth78's Avatar
udsuth78
Illuminati... or Aliens
Taylor Swift? Na she's to young, but Oprah... Nope I got it. Keanu and that damn Matrix
ynot321AB1
Oct 5, 2022 05:17 PM
Tuna Maniac
Mar 6, 2017 02:32 AM
52 Merc
Apr 10, 2011 06:57 PM
ram2miller
Nov 28, 2006 12:15 AM
