fuel fill inlet error
Old May 1, 2023 | 01:30 AM
now_what's Avatar
now_what
I was hoping I can pick your brain, I have a 2010 Ford F150 Lariat with a 5.4 V8 and about a month ago I got a warning on the screen saying check fuel fill inlet. so I searched and it is a common error for a loose or missing gas cap, but my truck has the capless tank. I tried cleaning the around the fuel door and where the gas door is with seafoam and pressure air and that did not work. Next I put a obd2 reader on it and go the error code and then erased the code and after 2 to 3 weeks it came back on. There is no performance issues with the truck, it's starts right up when you step on the gas it goes and does not spit or sputter. any idea what I should check out?
thanks
Old May 1, 2023 | 06:34 AM
projectSHO89's Avatar
projectSHO89
Follow the directions in your owner's manual for "cleaning" the capless fuel filler.
Since you didn't post the actual fault codes, can't comment on those.
Old May 6, 2023 | 09:40 AM
gDMJoe's Avatar
gDMJoe
Post
now_what...
As a follow-up to projectSHO89's post...
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
SEARCH BY VEHICLE
» Year & Model
» Year
» Model
» Search >
Old Jul 12, 2023 | 10:33 PM
now_what's Avatar
now_what
error code
I've cleaned it multiple time as instructed in the owners manual and even tried some techniques from youtube videos. Sorry i forgot to post the error code, and its Check fuel fill inlet P0457 Error
loose or missing gas cap.
Thanks
Old Jul 13, 2023 | 07:40 AM
Evets's Avatar
Evets
4wd Low
MY FIX...
Thanks
I fought the same thing for months. I cleaned and scrubbed the inlet multiple times with all sorts of cleaners, etc. Nothing worked. Then....I replaced the Purge Valve. Haven't had a code since.
Old Jul 13, 2023 | 08:00 AM
projectSHO89
The P0457 can be caused by a faulty seal in the capless filler, a loose gas cap (if equipped), a purge valve that doesn't open or close properly, a restricted vacuum line from the purge valve, a vent valve that doesn't close, or some other leak in the evap system. Because the monitor for this DTC is only supposed to run after a refueling event, it's usually assumes (but not always the case) to be related to a failure of the fuel inlet to seal properly.
Old Jul 13, 2023 | 04:54 PM
now_what's Avatar
now_what
Did you have any other performance issues? My truck runs great without any issues.
Old Jul 13, 2023 | 04:56 PM
now_what's Avatar
now_what
wouldn't there be other issues besides the error message? I'm not sure, trying to figure out where to start lol. thanks
Old Jul 13, 2023 | 05:01 PM
projectSHO89
This is strictly an emissions issue. Should not cause any driveability or operational issues.
If you have mandatory emissions testing, it will need to be either fixed or you'll need to figure out a way to make it pass when it's due. If you have no emissions testing, feel free to do whatever you want.
Old Jul 13, 2023 | 05:05 PM
now_what's Avatar
now_what
Thank for replying, I live in Montana and there is no emission testing here. I just don't like the error message lol.
Old Jul 13, 2023 | 06:24 PM
Evets's Avatar
Evets
4wd Low
There were no performance issues. Truck ran same as always. Just that incredibly annoying dashboard message!
Old Jul 13, 2023 | 06:45 PM
now_what's Avatar
now_what
so you changed the purge control valve?
Old Jul 13, 2023 | 09:47 PM
Evets's Avatar
Evets
4wd Low
Yes. All I did was change the purge valve. The code went away and has never come back.
Old Jul 13, 2023 | 10:10 PM
now_what's Avatar
now_what
sorry for so many questions, if this what you changed? I'll try to add a pic also. Thank you so much!
Dorman 911-378 Vapor Canister Purge Valve Compatible with Select Ford / Lincoln Models
Old Jul 13, 2023 | 10:39 PM
Evets's Avatar
Evets
4wd Low
Yes, that's the part.
Just a quick hint. I found it easiest to replace the purge valve if I laid on top of the engine facing the windshield and reached one arm around each side of the engine. You can't see what you're doing but it's very easy to feel the connections. Hope this helps.
