Rear Tires Inside wear?
Old 04-29-2023, 01:47 PM
carlrpatterson's Avatar
carlrpatterson
carlrpatterson is offline
1st Gear
I have a 08 F150 king ranch and has a 4 in lift and im noticing the inner edge of tires are wearing uneven?This is my first lifted truck.AQnd never had inner wear on rea tires come on any insite?Thanks
Old 04-29-2023, 02:14 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,725 Likes on 1,408 Posts
Welcome to FTE. I am moving you to the forum for your truck.
Are you the original owner?
If not, the previous owner could have overloaded it, jumped it, or otherwise banged it around enough to bend the rear axle housing.
Or perhaps the tires were rotated a while back and with additional wear are now showing the wear pattern started up front.
Have you had alignment checked?
The following 2 users liked this post by 85e150:
Old 04-29-2023, 02:23 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,348 Likes on 1,142 Posts
I'd first suspect tire rotation front to rear, what it reads like.
The following 3 users liked this post by tbear853:
Old 05-01-2023, 07:44 AM
WWR's Avatar
WWR
WWR is offline
Yeah I'm also wondering if fronts were rotated to rear.
Make sure the lift installer got the spring perches located on the spring center pins, but if your axle was wonky I'd expect one inner edge and one outer edge worn. Still, DO check this as many lift kits are installed by 16 year-olds in a driveway.
Also worth just verifying your shocks have life -- but again worn shocks typically cause cupping, not feathered edges.
If everything checks out, then yeah, your housing could be bent. Is this the 8.8 or the 9.75?
perryg114
11-20-2011 08:04 AM
61 uni
06-26-2009 12:37 PM
Mr truck
1999 to 2016 Super Duty
02-10-2003 01:10 PM
92Custom
06-27-2002 03:40 PM
fordmanSLO
03-14-2002 07:15 PM
Quick Reply: Rear Tires Inside wear?
