94 96 fuel pump interchange
Old Apr 29, 2023 | 09:22 AM
highpockets58's Avatar
highpockets58
I am back onto my ongoing engine swap in my 94 F150. It is a 5.0 and I am swapping in a 96 5.8. I have been waiting for spring so as not to disable my only 4WD and I think it is safe now. I also have the heavier transmission from the 96 but am going to just swap engines first and get the bugs worked out on that before switching transmissions which involves computer, wiring, driveshafts, etc. Question for today, my front fuel pump died a few months ago. I do have the rolling chassis here from the 96 I bought for the engine/trans. Is that fuel pump the same? I went onto Rock Auto and they show a dozen different fuel pumps, depending on steel/plastic, capacity and bunch of other confusing stuff. If that 96 one will fit and works, that would save me from buying a new one. Any help much appreciated. Thanks.
Old Apr 29, 2023 | 09:46 AM
highpockets58
Old Apr 29, 2023 | 10:59 AM
rla2005's Avatar
rla2005
If both tanks are steel and the same capacity they should swap. If one is a 17 gallon versus a 19 gallon version I do see different fuel module part numbers. You could just swap the pump only between the hangers if the assemblies are different.
Old Apr 29, 2023 | 11:22 AM
Scndsin's Avatar
Scndsin
There's a good chance the physical module is identical front/front & back/back.
The module its self you should consider as a "sump" so how it sits in the tank is what's important as well as pipe/connector orientation.
What will be different is the connector plugs (94 large, 96 smaller) which if you're skilled, you can re-pin or if not, splice.
When you pull a module, you'll see what each wire goes to. Red power, Black ground, Yellow level sensor, 4th, goes nowhere, does nothing.
When you get these out & if you pull the pump out of the 94 module, post the info off the side or a pic if stock. (Flow rate, etc)
Old Apr 29, 2023 | 03:48 PM
1Butcher's Avatar
1Butcher
What about swapping tanks. Might be easier.
I have come to the conclusion that fuel pumps die because the electric motor wears out. I have also found this to be true at around 150k-180k. If you are anywhere near that, I would get a new one. I would not shop by price. Get a good name brand and leave the Chinese junk for someone else.
Old Apr 29, 2023 | 05:02 PM
Ronniewhite's Avatar
Ronniewhite
I just got 2 Delphi pumps and they were made in China.
Old Apr 29, 2023 | 07:02 PM
1Butcher's Avatar
1Butcher
Delphi has a name to protect and although their pumps may be made in China, that does not mean they are junk. That is why I clarified to get a name brand item, not the lowest price Chinese junk.
North America has priced themselves out of manufacturing arena years ago. Someday, China will too some day, some say it has already happened.
SITCHY
Mar 24, 2010 11:59 AM
Zamobafood
Apr 28, 2008 09:46 PM
44dwarf
Jun 11, 2007 07:23 PM
streetrodcreed
Mar 17, 2007 05:16 PM
