Another AIH delete question. Code eliminator question
Old Apr 26, 2023 | 08:55 PM
Squirly's Avatar
Squirly
I fully understand what everyone does to eliminate the soft code when deleting the AIH. My question is what happens when the AIH is activated when using the 14gauge wire with 470ohm resistor in it?
Seems that the relay is large and would fry the little 14g wire that is grounded. And the little 470ohm resistor seems small as well and seems it would pop if the AIH was activated.
Any I out would be appreciated. I have read everywhere and have not seen the answer.
Yes I know the AIH almost never comes on but my point is can this little eliminator handle it when it does?
Thanks.
Old Apr 27, 2023 | 06:42 AM
GregA's Avatar
GregA
I think you may have some misunderstanding of electricity.
V=IR. Or said differently, I=V/R (amps equals volts divided by resistance).
13.5V/470ohms = .03A (ck my math)
14g is good for some 15A? And a resistor won't flow any more than its rated current, which is controlled by the delta-V.
Throw 10KV at it and yeah you might have a problem. But not with 13.5V
Old Apr 27, 2023 | 10:48 AM
Squirly's Avatar
Squirly
Yes my ohms law understanding is weak at best. So what you are saying is the relay does not push AMPs, but pushes voltage. The grounded 14g wire w 470ohm resistor will not be damaged when the regulator activates.
I still dont complelety grasp it though. The original AIH wires seem to be 12 gauge or so (can anyone confirm this?) Part of my concern is this fact
Old Apr 27, 2023 | 10:56 AM
GregA's Avatar
GregA
Originally Posted by Squirly
So what you are saying is the relay does not push AMPs, but pushes voltage...The original AIH wires seem to be 12 gauge or so (can anyone confirm this?) Part of my concern is this fact
Correct: the resistor will only flow amps based on the difference in voltage. 13.5V is not enough to create an amperage that will blow up either the resistor or the 14g wire.
I wouldn't say the relay PUSHES voltage, but OFFERS it. The resistor (any load) will only take as much amps as it is rated to pass, based on that delta-V.
I suppose you could think of it like water pressure in a hose, and the resistor as your thumb on the end; if your thumb is strong enough to stop the water pressure then the delta-pressure will not oversome your thumb's resistance. But if the water pressure is doubled (or more) then you may not be able to resist it.
The reason that the OE wire is larger is likely because the resistance of the AIH is less than 470 ohms, allowing higher amperage. - GA
island eddie
Nov 5, 2021 08:04 PM
weekendwarriorfsw32
16
Apr 20, 2010 11:15 PM
caleb90
Sep 26, 2009 11:15 PM
umdstang
Computer Chips & Tuners
Nov 24, 2003 05:22 PM
