Driveline Angles
Old Apr 26, 2023 | 06:56 PM
jhelliot's Avatar
jhelliot
Trailering
Driveline Angles
Looking for some advice on best way to resolve u-joint working angles.
Was having some vibration at higher speed so I pulled my driveshaft and took to a local shop. They said it was pretty much roached so they swapped yokes, u joints, phased all that good stuff.
While it was out I checked angles and pinion angle was way off.
transmssion yoke is 7 degrees down. Driveshaft was 1.5 degrees down and pinion was 7 degrees down (I shimmed it to match the trans.) I did reinstall driveshaft after I got it back and vibration seemed to be gone. However I’m concerned about the u joint working angle.
From my calculation, Which could be wrong, I’m figuring my u joint working angle is 5.5 degrees which seems excessive compared to 3 degrees I’ve seen listed as maximum.
with all that, what is the best way to correct this to get back to three degrees or less Assume I need to shim under the trans cross member. Also assume I’d need to loosen engine mount bolts to do this? once I can work out the trans angle shimming rear end to match shouldn’t be a big deal.
Old Apr 29, 2023 | 01:20 AM
thrifty's Avatar
thrifty
Did you use the shims they make for the pinion angle?
mojobaby
Sep 15, 2020 02:18 PM
notyettoday
Apr 20, 2020 03:23 PM
Ratty51F1
Jul 18, 2019 04:31 PM
we56
Jun 15, 2012 05:05 PM
he race me
Apr 2, 2004 11:21 AM
