EXPERIENCED Driveline angle guidence Wanted
Calling all who have experience in setting the driveline angles, welding in your motor mounts/trans crossmember & pinion angle and then drove your ride with SUCCESS and NO vibration issues or premature wear, the reason I ask for advice from the experienced folks only is the internet is full of OPINION even the magazine experts vary.
Most agree at least 1/2 degree difference at each end of the drive shaft to "work" the grease in the U-joints is needed ...I get that
So right now I am temporary mocked up with the truck on the ground/suspension loaded
Engine/trans 4 degrees (which puts the carb mounting surface at 0 degrees/level)[using Holley Sniper anyway so not really an issue]
driveshaft 3 degrees
rear end 2.5 degrees
That leaves me at a 1 degree difference for the front u joint & a 1/2 degree on the rear u joint
This is the first time I've done this and want to get it right the first time(who doesn't) I know I tend to over think things ALOT but like I said who wants to go back and redo when you have the time to do it right!?
PLEASE if you do not have Experience in these matters please refrain from possibly giving information that may not be real world, don't mean to sound like a jerk but all the internet opinions have me tearing my hair out already.
Thanks in advance
Thanks in advance
With my 5.0L and AOD install I also had to offset the engine about 1 1/2" to passenger side to allow for steering clearance on driver side.
You are within the ballpark for the engine -transmission angles, but make sure you also get the appropriate length for the driveshaft as well. I have a modified driveshaft because I have a 90's engine.transmission mated to a 2001 rear axle. I got a driveline shop to cut and balance the driveshaft, and confirm proper length to allow for travel when cornering.
Ok, I'll be a jerk. I have relied on Drivelines NW many times in marine and industrial applications and trust them implicitly. Yes, I have experience but not specific to your application.
https://www.drivelinesnw.com/part-tr...ngle-problems/
It doesn’t get any more real world experienced than right out of the Spicer manual. These guys have been building u-joints and drive lines for 100 years and this manual should be considered the bible of driveline installation. Much of this is geared towards big trucks, but the principles are universal. (Pun intended!)
Spicer Driveline Installation Service Manual User Manual | 24 pages
I spec the rear axle pinion to Center so engine is centered also
Yes the truck is sitting "on the ground" or cinder blocks so I have room to work underneath, the driveshaft was measured for in this state of on the ground (as is All figures I am using in these posts) and has 7/8" machined surface showing on the front yoke which is up to spec according to American Powertrain where I purchased the trans and who supplied the driveshaft after giving them my 54-5/8" dimension (dimension between trans tail shaft and rear end yoke)
Disregard the 5% in my pic... I meant to write 5 degrees, as you can see TCI (parabolic spring kit)calls for 5 degrees UP (some call this 5 degrees down but you get the picture here, it is UP towards the trans) After setting it on the ground it settled in at 2.5 degrees
Of course engine/trans is 4 degrees DOWN and drive shaft is 3 degrees DOWN
The 4 degrees down on the engine puts the carb mounting surface at 0 degrees or LEVEL which seems optimum to me although with the Holley Sniper I don't think that's really a big deal
harmdogg1978
09-08-2004 07:22 PM
thatdude
10-22-2003 02:29 AM
BlueBoy
06-30-1999 11:10 AM
