330ft or fe engine
Old Apr 26, 2023 | 03:48 PM
Rednek802's Avatar
Rednek802
7th Gear
330ft or fe engine
I recently purchased a 1979 f350 that was a former uhaul truck. The previous owner thought that it had a 330ft in it, but everything looks to me like it is an fe of some size. It does not have the front motor mount and the exhaust manifolds definitely look like they belong on a 360. The only thing that makes me wonder is there are bolt holes in the head that look like they would be where the crossover port on a 330ft manifold would bolt in the middle. Any ideas?
Old Apr 26, 2023 | 04:53 PM
Rubiranch's Avatar
Rubiranch
It looks like a 330 to me, possibly out of an old U-Haul truck or some kind of industrial equipment.
Old Apr 26, 2023 | 05:38 PM
Rednek802's Avatar
Rednek802
7th Gear
The truck is definitely a former uhaul truck. Aren't the exhaust manifolds from an fe engine though?
Old Apr 26, 2023 | 05:45 PM
j80's Avatar
j80
Trailering
I have a 78 f350 that was a uhaul with the 330 and it has the exact same manifold that is missing the two crossover bolts also. I don't know what they came off of buts it's identical to yours.
Old Apr 30, 2023 | 03:58 PM
Rednek802's Avatar
Rednek802
7th Gear
79 f350 330ft vacuum/carb
I have a 79 f350 former uhaul truck with a 330ft MD engine. I just purchased it and am trying to get it to run/idle good. It either has some vacuum leaks or I getting ready to swap engines as it has around 12" of vacuum at idle. I sprayed around some carb clean and it raises the idle pretty much around the whole base of the carb. My question is what is the oval shaped body on the side of the carb? It looks like it should have a hose hooked to the back. Is it a vacuum port or maybe a spot for a heated intake? Any help is appreciated.
Old Apr 30, 2023 | 04:36 PM
85e150's Avatar
85e150
Could be the governor.
I have some stuff about the governors in the Tech section at the top of the Large Truck forum. I'll try to find it and post a link later.
Old Apr 30, 2023 | 08:57 PM
85e150's Avatar
85e150
There are several threads here that talk about the guv. Illustrations etc.
https://www.ford-trucks.com/forums/8...l#post19447467
The item you are pointing out appears to be the altitude compensation device. A description and instructions here--all three illustrations are of interest with the 3rd one giving the close up detai of the item:
https://www.ford-trucks.com/forums/1...l#post19272191
NOTE THREADS MERGED. OP HAS PICS OF THE ENGINE UP ABOVE.
Old Apr 30, 2023 | 09:09 PM
85e150's Avatar
85e150
Your OEM exhaust manifolds had the exhaust port but not the bolts through the manifold. Pictures here:
https://www.ford-trucks.com/forums/1...l#post20777460
The manifolds above must be FE manifolds--they don't even touch the head where the exhaust port is:
https://cimg1.ibsrv.net/gimg/www.for...88966d9c3d.jpg
Old May 1, 2023 | 04:36 AM
Rednek802's Avatar
Rednek802
7th Gear
[QUOTE=85e150;20835069]There are several threads here that talk about the guv. Illustrations etc.
Good information. Thanks for the help.
Old May 1, 2023 | 04:42 AM
Rednek802's Avatar
Rednek802
7th Gear
They definitely look like fe manifolds but there are no leaks. You would think it would be pouring exhaust out in the center where they dont even touch.
cdcava
16
Aug 8, 2022 03:33 PM
BLCKRHINO
Jul 19, 2022 08:55 PM
Garou_22
Mar 24, 2021 12:12 PM
bowtieman55
WTB - Parts & other
May 14, 2015 10:43 PM
ford390gashog
Dec 17, 2007 12:28 AM
