Sponsored by: Auxito
Is a P0500 Code the problem with our ABS?
Old Apr 25, 2023 | 12:39 PM
old-dad's Avatar
old-dad
Hello all! For those who haven't been following my posts, We have a 2001 F150 SuperCrew (5.4L/2v, 2whl dr, auto trans, 245000 miles) that has a ABS light on. We also had a misfire in the #2 cylinder but we changed the COP and that appears to be fixed and the "Check Engine" light has gone out. Unfortunately, even though we've drive enough miles and drive cycles to clear codes, FORScan still shows a P1000 code. Here in California, most, if not all, smog shops won't do a smog check on a vehicle with a P1000 code so I can't register my truck.
The last time I checked the log in FORScan, a few days ago, it showed DTC's: It showed: DTC in PCM:P1000, DTC in GEM: B1318, and DTC in RAP: B2425. It also showed that it was unable to read the DTC in the ABS??
Today when I checked the log in FORScan, it shows everything above but it also shows another DTC in the GEM: DTC P0500?? When I look that code up it says it's related to the transmission speed sensor??
The check engine light is NOT on so I don't know why this code is showing in FORScan, especially since we haven't moved the truck more than a few feet since the last FORScan check.
Could this be the problem with the ABS light being on all the time? If so, why didn't this code come up sooner? Or is not related to the ABS system at all? I'm still a newbie using Forscan so I have no real idea of what I'm doing. I've found a few articles and videos on the internet but I can't find any real documentation on how to use it a 2001 F150. I can't even find the any drop-box links to spreadsheets on our 2001 F150 (but I admit I'm not too good at computers either) Having some printed info would be helpful for me, especially with my memory issues. If anyone here can offer any advice please know it's greatly appreciated. Thanks in advance
Old Apr 25, 2023 | 01:08 PM
Jon Freeman's Avatar
Jon Freeman
A P0500 code is a Vehicle Speed Sensor Malfunction.
Old Apr 25, 2023 | 02:35 PM
old-dad's Avatar
old-dad
Thanks! Is the VSS the speed sensor on the transmission? Or is it a wheels speed sensor? Either way, could this cause the ABS light to come on the dash?
Old Apr 25, 2023 | 03:49 PM
Jon Freeman
Do a search on youTube for instructions on how to replace the VSS for your model. ABS is a different animal. I don't believe they are connected.
Old Apr 25, 2023 | 06:27 PM
Airborne 82nd's Avatar
Airborne 82nd
First find out what auto trans you have there may be more than one in 2001 idk. I have a 97 and the vss is on the tail shaft. The info may be on the driver door jam
Old Apr 25, 2023 | 07:51 PM
pdqford's Avatar
pdqford
Typically the P0500 will trigger the MIL.
The B1318 says the GEM saw low battery voltage.
Be sure you have a good and charged battery whendoing your diagnosis.
The B2425 says one of your Remote Keyless Entry devices needs to be reprogrammed.
Have Forscan graph the VSS PID and one or more of the WSS PIDs to see what’s working.
Check ALL the fuses to see if the ABS module is powered up and alive.
How did FORScan indicate that the ABS was not talking?
Old Apr 25, 2023 | 11:29 PM
old-dad's Avatar
old-dad
Thanks everyone. It's kind of weird that that FORScan only showed the P0500 DTC today, and before? Plus< there is no Check Engine light on, which I thought would show up with the P0500
mikevv
May 10, 2009 01:01 PM
StorminTexan
3.8 & 4.2L V6
Jul 16, 2004 07:55 PM
nocal
Jun 13, 2004 06:48 PM
