2011 - 2019 Explorer Discuss the 2011 to 2019 Explorer
2011 XLT - charging system errors
Old Apr 23, 2023 | 12:05 PM
hurricaneredwv's Avatar
hurricaneredwv
1st Gear
I’m hoping someone has some advice. I replaced my battery yesterday and the alternator was replaced about 9 months ago. Even after a hard reset I am still getting a check charging system light. Battery and alternator test good by 3 different car parts locations. Serpentine belt looks good and no slips. Ignition off voltage is 12.x and running voltage is 14.x. Voltage seems to drop when rpm’s increase. All fuses have checked good. Since this just started a few days ago, I’m wondering if anyone might have insight? Could there potentially be a loose ground or another issue I’ve overlooked? Thank you for any help!
Also, the engine was replaced by Ford 9 months ago.
Alternator was an aftermarket Duralast that was put on by the dealership when they replaced my engine which I purchased separately.
Old Apr 23, 2023 | 01:04 PM
projectSHO89's Avatar
projectSHO89
Since this is a PCM-controlled charging system, you'll need to scan the PCM for any charging-related fault codes that may guide diagnosis.
SCRWDRVR
2004 - 2008 F150
Jul 1, 2018 06:30 PM
deerhuntertyler
19
Jan 11, 2013 09:53 PM
CptSD
Oct 6, 2010 01:39 AM
galyejf
Jul 16, 2007 12:37 PM
mmcrorey
Aug 4, 2003 03:20 PM
