E4OD shifts too quickly
Old Apr 22, 2023 | 10:24 AM
KenCam's Avatar
KenCam
6th Gear
Question E4OD shifts too quickly
I have a 94 E350 RV with 50k miles. It has a 460 and E4OD. When driving it want's to shift to the highest gear immediately. Shifting manually works fine. The PSOM tested good and the speedo works fine. The ECU had bad capacitors and a corroded trace but I was able to replace / repair them. I have no way to test though so it's possible that the ECU is the problem.
Is there anything else it could be?
Have any of you experienced this issue before?
Is it OK to drive long distances shifting manually?
Old Apr 22, 2023 | 10:28 AM
1Butcher's Avatar
1Butcher
Shift timing is done by the EEC IV computer so all the signals at the computer are checked and a decision to shift is given. I suspect if there is a problem, you would have a code. Assuming you do not have any codes, the shift timing is normal.
You could try programming the computer to shift at a different load, not something that the average person can do.
Old Apr 22, 2023 | 10:40 AM
KenCam's Avatar
KenCam
6th Gear
Thanks for the reply!
I'm assuming ECC IV, ECU, ECM are all the same thing. The computer that runs the engine/trans.
It's very possible that it is still bad after I tried to repair it. There was quite a bit of corrosion from the leaking capacitors. I ohm tested all the traces and repaired one but I don't know how to test the unit. RockAuto has them in stock for ~$150 (listed as a ECM) I guess I'll order one.
Old Apr 22, 2023 | 10:44 AM
1Butcher's Avatar
1Butcher
Yeah, it's all the same. ECU, Black box, ECM, ficken junk, the controller is called many things by many people.
If you love your vehicle, it would be worth $150 to have a spare. At least for me.
Old Apr 22, 2023 | 10:53 AM
KenCam's Avatar
KenCam
6th Gear
Well, $80 core charge so it would be a bit more if I kept the old one as a spare.
Old Apr 22, 2023 | 05:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a wire that when grounded tells the computer that the transfer case is in 4x4 low. This makes the shifts happen at a very low speed. I know your truck isn't a 4x4, but the computer doesn't know that.I don't have a wiring diagram to know which pin it is, but a search will probably turn one up.
Old Apr 22, 2023 | 05:40 PM
KenCam's Avatar
KenCam
6th Gear
I'll look that up thanks
Old Apr 22, 2023 | 07:37 PM
KenCam's Avatar
KenCam
6th Gear
That is interesting. I found this:
https://www.transmissiondigest.com/c...in-e4od-4r100/
I think this is what is happening to me. I'm not sure how to test it yet. Can I just cut a wire at the ECU? Once I figure out which one...
Old Apr 23, 2023 | 10:08 AM
1Butcher's Avatar
1Butcher
I have a 95 F250/5.8L/E4OD/2WD. I also have a Tweecer that I can see the programming of the ECU. I doubt if this can happen since the ECU knows it's 2WD.
As a professional, I like diagnosis and know why things are doing what they are doing. Cutting wires may be a cheap fix, but cutting wires [that may not be there because you have 2WD] is a terrible way to see if something happens. Just my thoughts.
Old Apr 23, 2023 | 07:04 PM
Mark Kovalsky
Originally Posted by 1Butcher
II doubt if this can happen since the ECU knows it's 2WD.
How does the PCM know that it's a 2WD? There were not unique PCMs for 2WD and 4WD. The same PCM is used for both, and the wire is grounded when in 4x4L to change the shift schedules.
Old Apr 23, 2023 | 07:07 PM
1Butcher's Avatar
1Butcher
Without a doubt, I would not question you, but with the coding and wiring harness, I would expect something to be different. If I am wrong [and probably am] I stand corrected.
Old Apr 28, 2023 | 04:45 PM
Blurry94's Avatar
Blurry94
The only two major players within the ECU for shift points are throttle position and vehicle speed. The ECU does have an RPM function, however, I've noticed those table are set so that VS and TP execute the shift first.
Old Apr 29, 2023 | 07:29 PM
KenCam's Avatar
KenCam
6th Gear
I installed the new ECU today and it fixed the issue.
I also picked up a code reader and pulled codes before and after.
I was getting a 633 before and not after.
Thanks for the help!
CaptainChaos
Jan 8, 2024 10:24 PM
250fordman
19
Jan 10, 2023 07:25 AM
Chaos 95
Oct 17, 2011 09:11 AM
Cdy1
Jan 11, 2009 02:33 PM
