F250
Old Apr 19, 2023 | 04:57 PM
Brando584's Avatar
Brando584
7th Gear
F250
I have a 2017 f250 that is misfiring in all cylinders I’ve changed sparks plugs, coil packs, wires and crankshaft positioning sensor. I have a snapon P1000 scanner and i can see that its misfiring but it not throwing any more codes. I have no engine lights and the scanner isnt showing any codes but it is showing misfires on current drive cycles and in the latest drive cycles. Im just annoyed and at a loss on what it could be..
Old Apr 19, 2023 | 05:25 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
6.2 I take it, since you didn't give full info?
Have you tested each coil and injector?
Tested the Harnesses?
Old Apr 19, 2023 | 05:56 PM
Brando584's Avatar
Brando584
7th Gear
yes i realized that after i posted it. But i have not tested the injectors nor the harness. Fuel related issues was my next guess but didnt know if someone knew or had the same issues
Old Apr 19, 2023 | 06:25 PM
Split rims's Avatar
Split rims
Broken valve spring?
Old Apr 19, 2023 | 06:36 PM
Brando584's Avatar
Brando584
7th Gear
no i checked valve springs ran pressure test on also.
Old Apr 19, 2023 | 09:07 PM
morehouse7's Avatar
morehouse7
What codes? P0316? CEL or no? Fuel changeover seasons can mess with them on a cold morning. Does it run like crap or you just happen to scan it?
Old Apr 19, 2023 | 09:22 PM
Brando584's Avatar
Brando584
7th Gear
no codes but no its at 156,000 miles i changed spark plugs coil packs wires and crankshaft position sensor and i relearned the system but its still misfiring the scanner is picking up that every cylinder is misfiring but you cant really tell unless the engine is under load like barely giving gas to keep up speed. It misfires from 1800-2500 RPMS. normal driving.
Old Apr 19, 2023 | 10:13 PM
morehouse7's Avatar
morehouse7
Did you change 16 plugs, coils, wires, and cps because it was doing this? Or now it's doing this after the swap? Did you replace with all OEM from a reputable source or did you buy aftermarket? Does your scan tool support Ford mode 6 misfire tool?
Old Apr 20, 2023 | 07:48 AM
Brando584's Avatar
Brando584
7th Gear
yes i did all 16 plugs all 8 coil packs all 8 wires. I dont know what CPS is so im goin to say no. And now i wemt to oreillys and get the parts. Except wires they cane from ford. And I honestly dont know if it does or not its a snapon P1000 scanner.
Old Apr 20, 2023 | 08:53 AM
DSLTRK60's Avatar
DSLTRK60
Crankshaft position sensor.
Also, did you check/load test battery?
Old Apr 20, 2023 | 09:50 AM
Brando584's Avatar
Brando584
7th Gear
yes I replaced that sensor and relearned the truck. But no i didnt. Test the battery.
Old Apr 20, 2023 | 10:18 AM
morehouse7's Avatar
morehouse7
Are you on the stock original battery? They are not very good to say the least, if you are just do yourself a favor and change it to a Odyssey AGM or Northstar AGM or Batteries Plus X2power AGM. If you were misfiring on every cylinder and changed all that stuff and did the CPS relearn you need to look at the battery/alternator system, fuel, vacuum leaks... the things common to all cylinders. I am still a little shocked you aren't seeing a code recorded but I don't know what the qualifications are exactly.
Old Apr 20, 2023 | 08:15 PM
Brando584's Avatar
Brando584
7th Gear
I couldn’t tell you on the battery deal. But yes i will definitely be looking into them. I appreciate it.
Old Apr 21, 2023 | 02:59 PM
chipone's Avatar
chipone
could a throttle position sensor be possible on these trucks?
troy98f150
1997 - 2003 F150
Dec 22, 2022 09:50 AM
nichol83
Oct 22, 2021 06:19 PM
Ericnelson
2009 - 2014 F150
Aug 2, 2021 12:57 PM
godblessmerica
May 29, 2021 06:53 AM
Bebopjop
6.2L V8
Oct 17, 2020 12:49 PM
