Sponsored by: Auxito
p306 and p307 codes
Old Dec 21, 2022 | 05:16 PM
troy98f150's Avatar
troy98f150
4wd Low
p306 and p307 codes
I am getting p306 codes but sometimes also get p307 code. I am thinking this can not be good since these
cylinders are right next to each other. Replaced coil packs and wires. Have not replaced plugs yet because
thinking both cylinder 6 and 7 would not likely go bad at same time. What do you think can be the likely issues?
Old Dec 22, 2022 | 09:50 AM
manicmechanic007's Avatar
manicmechanic007
Inspecting / Replacing the spark plugs is what you should do first
There is a whole lot to it. (engine miss on a 5.4)
Consider doing a compression test on both those cylinders
If you are lucky, the plugs are just worn out or fouled
Unlucky cam is flat or the followers are worn broken etc.
Consider pulling the valve covers for further inspection
bowtieboy77
2015 - 2020 F150
Oct 15, 2021 10:18 PM
Ericnelson
2009 - 2014 F150
Aug 2, 2021 12:57 PM
ja.mc44
Apr 11, 2021 09:03 PM
smedly73
Modular V10 (6.8l)
Apr 26, 2011 12:58 PM
damnford101
1997 - 2003 F150
Jul 14, 2010 03:04 PM
