Explorer '94 brake noise
Old Nov 17, 2003 | 01:26 PM
gbrad568's Avatar
gbrad568
Help!! I just bought a used '94 Explorer in mint condition. Previous owner did everything in maintainence. Problem is there is a grinding/grating sort of noise when ya apply the brakes. We pulled the wheels, rotors are great, pads are like new, bearings are properly adjusted, i.e., not loose or over tightened. It almost sounds like the suspension is making the noise when the front of the vehicle dips down. ABS light goes out when started, hubs looks OK. Everything looks good but the noise is still there. Previous owner gave up on the problem and sold it with problem still there. Any ideas, suggestions, etc??????????????
Old Nov 18, 2003 | 07:46 AM
joemajesty's Avatar
joemajesty
front end noise
i had the same problem in my front end and discovered that it was the radius arm bushings, replaced and greased
Old Nov 18, 2003 | 12:00 PM
gbrad568's Avatar
gbrad568
Thanks. It does sound like a suspension noise. The radius bushings have been replaced by previous owner. Looks like they are OK, but I wonder............ Will check them out this weekend.
