I have wind noise around the driver side mirror but i cannot pinpoint it. I can fold it in but it doesn't change anything. Just check to see if anyone has had this happen to them. It has the cameras in the mirror.
Hi there! I can look into your F-150’s noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your F-150’s VIN?
I had the same problem with a 2019 Ford F150 Platinum, dealer said nothing was wrong so I pulled off the mirror myself, cut out another piece of foam sheet and added to the existing foam surround, put the mirror back on and noise was gone.
I bought a 2023 Ford F150 Platinum Hybrid this past weekend, cannot connect to Fordpass, Wi-Fi, etc, sales told me it was my phone, sales called Ford Pass and they said to get a TSB done, went to service, they say it was already loaded, tech got it to load, well yes it will load but you cannot activate. Was on phone with Ford Pass yesterday and again they told me to load the TSB. Again service said must be my phone cause tech got it to load after second call. Today I got deeper into Ford Pass tech help, finally was told today that this is a none problem with 23 Broncos and F150s, there is a OTA pending on my truck that should fix problem, basically the moden is asleep and the OTA will wake it up. Of course if it doesn't load OTA I will have to go to dealer to get it loaded. If so I will go different dealer. Update, received OTA update an hour ago and FordPass now authenicates, wifi setup works all is good. Thanks to the FordPass Tech Support team.
Break, break,
I love the truck so far, beside the problem above I had a carpet issue that I fixed myself, tech just looked at it and said he could pull the carpet over but I did myself, my problem now is nobody makes a bug deflector for my Platinum with BAP which somes with Tremor hood, I called AVS, Ford, Lund etc, nobody has one, no one will commit to making one, all they would say is keep checking our website. DUH!
rbushnell: while you wait for a bug deflector to be made, why don't you look at the 3M clear film you can apply. It will protect the hood really well and isn't that noticeable. Pricey stuff but it works.
[QUOTE=Skidrowvet;20879741]i also have a sort of "noise" like a rattle from my driver's side window(?) it's not always but when it is it's pretty annoying.
nope, when it does appear I get pissed and say I'm gonna do something then it goes away, and I forget about it until the next time lol- Apparently this is one of the hidden pleasures of owning an F150 LMAO.
Damn, it pisses me off too. It seems like when the wind direction is blowing towards the truck is when I hear it. Mines on the passenger side. Sounds like something rattling outside the window. So idk what to do. Lol
when it first happened to me I took it to the dealer and of course the never hear a damn thing, but I have read where guys have taken their whole door apart, even replaced everything and couldn't find anything- After 2 1/2 years i just turn up the music- Some guys even have a rotten time with their A/C and gremlins in THAT system.This is my first new truck since 1980 and , although I love the truck-there are a couple of little things that are annoying- like a plastic oil pan-WTF is that about
Found my rattle to be the seatbelt rattling against the door. Might check that..
