C4 leaking at the speedometer cable
Old Apr 16, 2023 | 03:04 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Hopefully I can get an easy fix for a persistent issue. I've yet to get my 56 F100 on the road but it continues to leak from the speedometer cable. I know, a 56 didn't come with a C4 but thanks to Flat-O mine has a C4. I have installed 3 different speedometer cables from two different manufacturers but all leak. Now this is while the vehicle is sitting since I've yet to get to drive my F100 on the road. So has anyone got any ideas?
Old Apr 16, 2023 | 05:09 PM
tjc transport's Avatar
tjc transport
i ain't rite
have you put a gasket between the cable and tailshaft?
if i remember correctly, there should also be an o-ring or two in the cable end too.
Old Apr 16, 2023 | 05:28 PM
bjmayberry2
I can't find where a gasket (I'm assuming an o ring) would go. It's just a push in plug that has a rubber O ring) that's held in with a clip that's bolted into the tail shaft housing.
The oil is dripping out of the cable after the factory crimp.
Old Apr 17, 2023 | 04:25 AM
JWA's Avatar
JWA
Is this the cable itself leaking?
Old Apr 17, 2023 | 09:38 AM
bjmayberry2
Yes, I'm not sure how to prevent ATF from getting up into the cable???
Old May 7, 2023 | 09:56 AM
bjmayberry2
I was hoping to get this solved but nothing so far. Here's what I have.
Speedometer gear marked 20-3
End of speedometer cable gear does not fit inside
C4 Automatic
hwyhogg
Feb 16, 2014 07:40 PM
1970Nifty250
Feb 24, 2013 10:57 PM
fast58
Oct 11, 2011 07:32 AM
newblder
Sep 11, 2009 10:16 AM
