MIG welder settings for panel work.
Ooppps I forgot I'm practicing on some 3/16 thick box tubing so I'll need settings for that too. Also how do you know if the wire speed is too fast or slow?
75%Argon/25%CO2 . Keep your nozzle clean also. Buy an anti-spatter spray or gel such as Nozzle-Kleen or cheap alternative like Pam cooking oil spray. This is necessary to keep the gases to come out smoothly and will protect your welded pieces better.
Do I just spray the Nozzle Clean up into the cone? If I spray the Pam on the part to be welded will it effect the weld. I was told to do this so the little ***** of splatter would not stick. I have a glass beader and most stuff will be prepped that way.
first off, as for gas, the more argon in the tank the less splatter and prettier weld youre going to have, but i actually have used straight C02 for a long time with fine results. the spray stuff that hes talking about does help alot, but i dont touch the stuff because it smells awful and i hate working with it for more than 2 minutes.
second, if youre just beginning, your friend is right you need to get that frying egg sound, it will sound more like a constant sizzle. you dont wanna hear any jumping or crackling, just a constant sizzling sound. in order to get it, dont worry about what the numbers are on your power and wire speed settings, just practice on a piece of metal roughly the same thickness and run several beads until you get the welder to the desired setting.
it takes practice to just turn it to where you want it every time.
also, generally if you have a lower voltage you are gonna want a much slower wire speed, and vice versa. be real careful on thin body metal and dont stay in one spot for long at all, youll burn through it in a heartbeat and possibly warp the metal somethin awful.
hope it helps
