Wheel Spacers
Old Apr 20, 2023 | 11:58 AM
knottyrope's Avatar
knottyrope
Isn’t that the point of the spacer being hubcentric? Shear/sideways loads are taken by the hub, not the studs?
Hub-centric wheels are designed for the center bore of the wheel to be a perfect match to the vehicle's hub, sometimes called a hub pilot. This allows the wheel and tire assembly to be centered on the hub, which is the most accurate way to install your wheels.
Hub-centric rings
don't carry any load and are not required for a secure installation as the studs hold the rim on to the hubs
Old Apr 20, 2023 | 12:32 PM
00t444e's Avatar
00t444e
Why do spacers that use studs that come all the the way through from the hub put more stress on the the studs?
Because the studs have to be longer and so does the threaded area between the lug nut and the hub which makes it more prone to stretching.
Old Apr 20, 2023 | 12:41 PM
FordTruckNoob's Avatar
FordTruckNoob
Hub-centric rings
I learn something new every day. According to this article, the vertical load is carried by the friction between the wheel and the hub which is achieved via the tension in the stuf holding the wheel to the hub though. So how does a longer stud experience lateral loads if properly torqued?
https://www.onallcylinders.com/2016/...d%20to%20specs.
Old Apr 20, 2023 | 02:39 PM
knottyrope's Avatar
knottyrope
thats the issue
if you get longer studs, it should be ok as the non threaded part would go through the spacer for strength
fender1325
Apr 23, 2022 10:02 AM
Heavy hual guy
Jun 18, 2020 03:54 PM
Jason 05 EB
Jun 16, 2013 10:03 PM
seayya
Jul 13, 2007 03:05 PM
jcs1966
Jun 25, 2003 07:40 AM
