Engine cleaning
Old Apr 16, 2023 | 04:08 AM
Rainmaker1's Avatar
Rainmaker1
Engine cleaning
Update; ok so a week ago this past Monday the shop made good standing behind their work and replaced the hi pressure oil line fitting at the head on the drivers side. The second opinions were correct and now after almost two weeks not a bit of a drip. It’s such a relief looking under on the ground and not seeing any signs of leaks.
Next, the entire engine bay needs a good cleaning. There’s residual grime, grease, etc. I understand steam is the way to go over using chemicals and water.
I checked Yelp and found prices anywhere from $150 - $250. One guy quoted $45.
Is steam cleaning the way to go and if so, what should it cost? Also, is it a service that detailers do or who does engine cleaning?
Old Apr 20, 2023 | 05:15 PM
450kexcursion's Avatar
450kexcursion
You will probably have to pay for a full truck detail and then they will add a engine detail. Which a engine detail will be most likely double the price of a gas engine due to the simple fact a diesel engine gets much more dirty.
Old Apr 20, 2023 | 09:52 PM
John in OkieLand's Avatar
John in OkieLand
fill a bucket with Royal Purple and a good paint brush, and wash it down yourself.
driveway degreaser works good also.
rinse it off with a garden hose, much cheaper than a steam cleaner, which is nothing but Hot Water and maybe some degreaser in it.
Rose Clifford
Appearance & Dress-Up
Feb 1, 2011 10:55 PM
conderd
16
Oct 2, 2010 12:28 PM
mongo75
25
Nov 30, 2009 03:35 PM
firefighter1416
1997 - 2003 F150
Jul 13, 2009 09:20 PM
1975Ford
Jun 12, 2006 08:19 AM
