Just thought I would bring this up before anyone else got hurt.
A brother of a friend of mine was grinding on a car trailer, when his grinding disc exploded! The disc severed his jugular vein and he nearly bled to death before they could get him to the hospital. He has been in the hospital for a month now, has had two strokes, with a good possibility for more. His car hobby and his working career are gone. He will be lucky to be able to take care of his own daily needs from now on.
Let's list some safety procedures:
Keep the guards on all power equipment.
Never put yourself in direct line of spinning discs.
Check for cracks and chips in discs.
Wear protective equipment(face shield,goggles,clothing.etc)
If it's a bench grinder don't use it to grind aluminum. Use extra caution cutting overhead.
A friend of mine was just using a zip cut disc on a grinder and working on something overhead. The grinder slipped out of his hand and fell on his leg, seriously cutting it. He required 48 stitches to close the wound.
Good rule of thumb is that if you drop a grinding/cutting wheel, be it for a bench grinder, hand held angle grinder or a gas/electric cut off saw, replace it before using it. Your life/limbs are much more valuable than a $2-$20 grinding/cutting wheel. You can do the ring test on it, hold it up with one finger by the arbor hole and lightly rap it with a wrench. If it "rings" it's OK to use, if it makes a dead "thud", throw it away. Always inspect all grinding/cutting discs before each use, especially if someone else has used the tool before you.
Make sure the rpm's on the grinding wheel match the rpm's on the grinder. The rpm's on the grinding wheel can be lower but not higher than the max rpm's on the grinder.
Always wear safety glasses and a full face shield.
Aw to be 10 foot tall and bullet proof again. These are lessons learned the hard way.
Mike W is correct, this also applies to all soft metals, such as those brass drift punches that mushroom after so much use. Use a hacksaw or sawzall, not cutting disk.
Smitty7, did you state it correctly when you said the rpm's on the grinding wheel can be lower but not higher that the max rpm's on the grinder, or is it the other way around. I don't know, but it sounds odd that way, just checking.
You're right, the rpm's on the wheel can be higher than the rpm's on the grinder, but not lower. Thats the second mistake I've made this year.... no wait I'm wrong ...again!
Originally posted by smitty7 You're right, the rpm's on the wheel can be higher than the rpm's on the grinder, but not lower. Thats the second mistake I've made this year.... no wait I'm wrong ...again!
