Starting problems
Old Apr 28, 2023 | 04:56 PM
  #46
tjc transport's Avatar
tjc transport
i ain't rite
time for injectors.
and once you put the injectors in, start saving for an injector pump, because new injectors tend to tear up marginal injector pumps.
Old Jun 1, 2023 | 08:55 PM
  #47
akidd5777's Avatar
akidd5777
Parts
I am trying to figure out what these pieces are for in this set up bought it from russrepair.com
Old Jun 2, 2023 | 03:56 AM
  #48
tjc transport
i ain't rite
fuel line "olives". when you tighten the fuel lines they crush and look like olives.
they go on the steel inlet and outlet lines of the fuel filter, and inlet line of the injector pump.
don't remember where the fourth one goes.
Old Jun 3, 2023 | 03:24 PM
  #49
akidd5777's Avatar
akidd5777
So just finished replacing injectors and return lines. Any advice to start it now. Cant seem to get fuel to the lines on the injector. But have fuel at my water separator.
Old Jun 3, 2023 | 04:24 PM
  #50
tjc transport
i ain't rite
it takes a while to prime the fuel system. i have an electric pump, so it is easier for me.
do not crank engine for mere than about 45 seconds, with 2-3 minutes off to let starter cool off.
i remove the line from the fuel filter at the injector pump and crank till i get fuel to the pump. than hook up line to pump, and crack 4 of the injector lines loose.as fuel gets to the injectors i close those lines, and crack the other 4 lines loose.
usually takes around 15 minutes to get fuel to injectors with a dry system.
with the electric pump i can prime in under 5 minutes.
Old Jun 3, 2023 | 04:31 PM
  #51
akidd5777's Avatar
akidd5777
Alright. I have been doing on and off cranking. Was cranking great. Guessing I just drained the battery. Because now it cranks really slow and still doesn't seem to be trying to start.
Old Jun 3, 2023 | 05:00 PM
  #52
tjc transport
i ain't rite
yea, you only get about 20-30 minutes before the batteries die.
disconnect the glow plugs when priming with a mechanical fuel pump. they EAT batteries.
Old Jun 3, 2023 | 05:04 PM
  #53
akidd5777's Avatar
akidd5777
Luckily glow plugs are connected by push button. Just trying to get it to prime. I'm getting a little fuel to the lines now. Just gonna charge it up and try again I guess.
Old Jun 3, 2023 | 05:59 PM
  #54
tjc transport
i ain't rite
patience is the key here.
Old Jun 3, 2023 | 09:38 PM
  #55
akidd5777's Avatar
akidd5777
Got it started apparently my helper disconnected the fuel solenoid. Plugged it back in and it started first try. Sounds much better will send a video later.
Old Jun 4, 2023 | 08:29 AM
  #56
tjc transport
i ain't rite
i hate when that happens!!!!!
Old Jun 5, 2023 | 07:07 AM
  #57
akidd5777's Avatar
akidd5777
Alright. Right now I'm dealing with minor leakage from a few injectors. So my question is; should there be orings on top of the return lines in between the injector nut. That's what the previous owner had but I've been fighting leaks since I bought it.
Old Jun 5, 2023 | 08:13 AM
  #58
tjc transport
i ain't rite
No. The o rings go on the injectors themselves under the plastic caps.
th pump to injector steel lines are flaired ends
Old Jun 5, 2023 | 08:29 AM
  #59
akidd5777's Avatar
akidd5777
That's what I was thinking. Not sure why the previous owner had them on there. I made sure to install the orings on the injectors. Will remove the ones from the return line caps. Maybe they are keeping them from fully sealing.
akidd5777
Jun 3, 2023 05:55 AM
Slowhite777
15
Aug 10, 2022 12:56 AM
beersy50
17
Jul 12, 2008 10:24 PM
beagledog
Mar 21, 2008 10:21 PM
Dennis690
Mar 18, 2004 07:55 AM
