For Battery Cables, I have them made at NAPA.
A year or so ago had 2 Negative cables made, with Copper Ring Terminals.
Last week had 2 6GA made for my one wire Alternator. Crimped, Soldered
and heat Shrink`ed.
Much better that off the shelf, one size fits all.
Alright here is a video of start up. Not sure why air comes in to my lift pump like that. Or why it smokes just trying to figure out as much as possible and I know some people know what a good motor sounds like not sure if mine sounds like it should either all recommendations are appreciated.
You're only firing on 6-7 cylinders. The smoke is the unburnt fuel expanding in the hot exhaust pipe. First thing to do is figure out why cylinders arent contributing to the engine power.
you can do this by loosening each injector line b-nut, one at a time, and see which ones affect the idle. The ones that don't affect the idle aren't making power. Once you identify them, you need to do a compression check to see the health of the cylinder.
1: 315
2: 388
3:254
4: 362
5:313
6: 314
7: 250
8:250
these were my exhaust temps. After a good drive around town. Would it be safe to assume I am dumping fuel into cylinder 4 and cylinder 2 given the high temps? Also to double check odd cylinders run down passenger side and even on driver correct?
Hmm. I'm not sure that's an accurate way of determining cylinder contribution. Thermal conduction and airflow inside the engine bay will contribute to the temperature spread.
Thank you for the insight. Like I said I'm still new to this. Was suggested by other groups to check the exhaust temps at each head. But also was not specific to the idi. I will hopefully get my hands on a compression test kit soon enough to determine which cylinders may be my problem.
I don't think you have a compression problem. I think you have injector problems.
as said, loosen the nut on top of the injector with engine running and listen for a Change in the way it runs.
once you determine which cylinder(or cylinders) are the issue, swap the injectors to another hole that is working properly. If the issue follows the injector, the injector is bad. If it stays inn the same hole, the engine has issues.
alright everyone. Just tried the test where I loosened the b nuts for injectors 7,8,3. All had no effect on the way the truck ran. Also tried 2 and 5 made the truck shake hard.
New ones are cheap. Just buy new Stanadyne injectors. But check your compression first. No point in installing injectors in an engine with only 5 good cylinders.
So i tried this last weekend since I'm still waiting to buy a compression kit. (blew my budget for my hobbies for april.) Re tested the injectors by loosening the b-nut. (Kept track of the actual injectors though) the injectors seem to be the problem as now the 3,7,8 cylinders work fine. But the 2, 5, 1 cylinders don't which is where I moved the suspect injectors
