Cab wire harness interchange
Old Apr 12, 2023 | 11:43 AM
Grendel's_virtue's Avatar
Grendel's_virtue
Trailering
I'm working on a custom project.
- I have a 91 engine bay harness
Will an 89 cab harness be compatible with the 91 engine harness?
Thanks!
Johnny
Old Apr 12, 2023 | 12:39 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
You can probably make it work, but I would have EVTM's for both years handy.
The cab connector is the same for both years, but you may have to repin a few wires. Ford did make subtle changes each year.
I think 91 is the year they switched from the frame mounted hi pressure fuel pump to hi pressure in tank pumps. That will cause an incompatibility, but it can be resolved.
Old Apr 12, 2023 | 01:00 PM
Grendel's_virtue
Trailering
You're right about the fuel pump change.
The base truck is an 87. I pulled all the old wiring out, because everything was cracking and fraying, and now I'm in the rebuild phase.
I think I'm going to use a 91 cab harness and add a ground/power/scavenged plug to the new rail pump I put on a couple years back. Any thoughts on that? Can the rail pump share power with the in tank pumps?
Thanks!
Johnny
Old Apr 12, 2023 | 01:18 PM
NotEnoughTrucks2014
Sure can. Make sure you take the rail pump power before the tank switch so it runs with either tank. FP relay is the same in both systems.
Old Apr 12, 2023 | 01:32 PM
Grendel's_virtue
Trailering
Awesome.
Thanks!
Johnny
jlee8059
Dec 17, 2020 02:16 PM
Chips2000
Jun 12, 2018 06:21 PM
master_mechanic
Modular V8 (4.6L, 5.4L)
Jan 15, 2012 11:46 AM
77 ford shortbed
Jun 15, 2008 08:29 PM
indian_outlaw87
Aug 30, 2005 01:03 PM
