Exhaust manifold bolts and gaskets 5.4.
This is the set I have. I am hoping it is not to bad seeing FORD already replaced them. I CAN ONLY HOPE. lol
https://www.amazon.com/dp/B08KZMBKZP...roduct_details
Best to get an acetylene torch...Heat the nut first to red let cool 20 secs and try....Do over till it comes off...You can also spray with water...
To get the studs out do the same thing But you will need the tool I mentioned..Heat is your friend...
Spaying stuff on like PB I don't feel does much.
Also you can cut all the nuts off with a cutting torch then take manifold off and use stud tool..You break em off flush and then the fun starts..
As me how I know...LOL
saberworks
1997-2006 Expedition & Navigator
16
10-29-2010 11:34 AM
