Differential Gaskets ???
Old Apr 8, 2023 | 09:48 PM
Motown Fire's Avatar
Motown Fire
Who has part numbers or links for front & rear differential cover gaskets for our trucks? (My specific truck is in signature)
I am not gluing my differential covers on when I change the lube in them next time.
Thank you for all that help with information. Have a Happy Easter.
Old Apr 8, 2023 | 09:53 PM
WE3ZS's Avatar
WE3ZS
Look into a set of LubeLocker reusable gaskets, mine have been great.
Old Apr 8, 2023 | 10:00 PM
Motown Fire
Thank you WE3ZS, I’ll check that out.
Old Apr 8, 2023 | 10:03 PM
4wd6.7L's Avatar
4wd6.7L
I would also suggest LubeLocker. Last I looked they claim that their Dana 60 gasket doesn't fit the "Super 60" (front diff), but it does fit. Also, they might not have one for the Dana M275, if that's what you have in the rear.
Old Apr 9, 2023 | 06:08 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
LubeLocker. Get them on Amazon.
Old Apr 9, 2023 | 06:37 PM
Motown Fire
Thank you 4wd6.7L & ATC Crazy.
Im ordering from LubeLocker.
Old Apr 10, 2023 | 05:57 AM
Pugga's Avatar
Pugga
I went with a Banks Diff Cover replacement. It has a rubber seal and drain and fill ports. I wasn't going to glue mine back on either.
Old Apr 10, 2023 | 06:50 AM
rufushusky's Avatar
rufushusky
Good call with the lube locker, people really seem to like them. I went with the felpro on my rear diff and it leaked almost immediately, pulled it apart again and resealed with RTV. Next time I will go with the lubelocker for the rear.
Old Apr 10, 2023 | 08:01 AM
09FX-4's Avatar
09FX-4
If you have the Dana you don't need to pull the cover to drain... lower right bolt will drain it.
Old Apr 10, 2023 | 08:44 AM
carbonation's Avatar
carbonation
Lube Locker for Sterling and M275.
Nothing out there as far as gaskets for the M300 in the F350. I contacted FelPro and Lube Locker, they simply are not making them.
I used silicone, TA31 from Ford.
Old Apr 10, 2023 | 10:05 AM
HRTKD's Avatar
HRTKD
I don't see a gasket for the Dana M275 on the LubeLocker.com website. Did I miss it? I do have the gasket for the Dana Super 60, which has yet to be installed.
I did see a gasket for the "F6R140". Is that going to fit the 6R140? I know, duh, it's in the name of the product, but there's no description for it on their webpage and I don't think I've seen anyone on the forum use that gasket for their transmission.
Old Apr 10, 2023 | 10:41 AM
whagen's Avatar
whagen
The front axle on 2017+ SRW F250 & F350 are dana 60, not super 60, correct? The LubeLocker Dana 60- LLR-D060 will fit?
Old Apr 10, 2023 | 10:51 AM
HRTKD's Avatar
HRTKD
Nope.
a1z2s3x4's Avatar
a1z2s3x4
That is what I used on my 2022 F350 front axle. Lube Locker LLR-D060. Worked perfectly so far. Fit well, no leaks yet.
I bought it from Amazon @ $21.99 about one year ago. Shows over $26 now as I type this.
Amazon Amazon
Chris
Old Apr 10, 2023 | 10:58 AM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by HRTKD
Nope.
Correct, it is the Dana Super 60 BUT the LubeLocker Dana 60 gasket does fit, contrary to what the LubeLocker site says.
