Reversed battery connection
Old Apr 7, 2023 | 06:09 PM
Juliah's Avatar
Juliah
2nd Gear
So this is completely off topic and I just joined so I’m not sure where I go to ask questions maybe your or someone that sees this can help possibly? I’d appreciate it tons If so! So my son put a new battery of of one the other vehicles into our 2000 expedition in reverse. I tried to rectify and set it properly, but the terminals are sparking in the correct position. Also, the alternators smoked some battery is good cables are good checked with multimeter. Any advice would be great. Thanks guys.
Old Apr 7, 2023 | 06:46 PM
Rusty_S's Avatar
Rusty_S
Hate to be the bearer of bad news but hooking the battery up backwards on any computer controlled vehicle will fry multiple circuits. At the very least youll need a new ECM/PCM possibly more.
Old Apr 7, 2023 | 06:48 PM
FuzzFace2's Avatar
FuzzFace2
Juliah you are in the wrong area and should be posted over here https://www.ford-trucks.com/forums/forum27/
Also best to start your own thread and not tag on to others as information can get all mixed up between the OP and yours.
But as a hint if the magic smoke was let out of the alternator then that could be why the cables spark when hooked up but more testing would be needed to make sure.
Dave ----
Old Apr 7, 2023 | 07:07 PM
85e150's Avatar
85e150
Posts moved to correct forum for this vehicle.
The alternator--smoked or smoking?
When you connect the battery correctly, is there a small spark as you connect, or does it spark, heat up and smoke?
Old Apr 7, 2023 | 07:08 PM
RLXXI's Avatar
RLXXI
Disconnect the large wire on the starter and the alternator. Try connecting the battery cables again and see if the sparking occurs, if it doesn't (which I suspect it won't) touch the large wire back on the alternator or starter and see if either sparks, if it sparks note which component it does and replace it.
Repeat for the other component if sparks result when connecting it's large wire.
Old Apr 9, 2023 | 12:46 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Small spark for a fraction of a second is probably a good sign. Like the size of the tip of a pen, and not loud. If this is all it is, then leave it connected and make sure it doesn't get warm in the next few seconds, then see if it starts etc.
Large sparks are bad, like big and loud and maybe with a buzzing sound accompanying it. if it connects like this, the terminal will probably get hot in the next few seconds after it is connected.
If connecting it causes smoke anywhere, then disconnect and consider having a professional look at it, or prepare to start some major electrical troubleshooting if you know how to work on cars.
Welcome aboard!
kr98664
Oct 19, 2020 11:03 PM
79F-1504x4
53
Mar 3, 2011 01:53 PM
jmurder
Electrical Systems/Wiring
Nov 11, 2006 09:42 PM
97 RED PSD
1997 - 2003 F150
Dec 21, 2005 12:01 AM
SmittyD
Bronco II
Jan 17, 2004 06:57 PM
