Stumped 1993 7.3 E40D
Old Apr 5, 2023 | 11:50 AM
LukeTheDuke256's Avatar
LukeTheDuke256
Trailering
Exclamation Stumped 1993 7.3 E40D
Tried hooking up a trailer(5x8 utility) up to the truck to make a run to the landfill. Drove 45 minutes home and started up to move the truck around to the trailer around the house and everything worked as it should. After hooking up the trailer and attaching the 4pin I started the truck and noticed a lack of power in OD, as well as my speedometer and tachometer sitting at 0 with the truck on and moving, all other gauges still worked properly. I had fixed this issue when I bought the truck by replacing the VSS and Tach Sensor, so they were no older than 8 months at this point, but I still replaced them again, also no VSS on transmission. I didn’t move it far enough for it to try to shift. It does go into reverse, 1st and, 2nd with proper power but only OD is in limp mode. Whenever I start the truck the needles will flutter but still rest at 0 while running. I checked every fuse under the dash as well as the fuses in the engine compartment, none were blown. I plan on pulling the cluster to check connections today. Has anyone on here ever dealt with a Speedo/Tach/OD issue this persistent?
Old Apr 5, 2023 | 12:21 PM
Scott in TX's Avatar
Scott in TX
I don't know the answer to your question, I had a fluttering / dead tach and fixed it with a new sensor. I still had a mysterious flashing o/d light I pulled the dash and cleaned the connections on the plug and it's ran fine since, I really didn't think it would work but I was out of options,
Old Apr 6, 2023 | 01:07 AM
Charmalu's Avatar
Charmalu
If Mark Kovalsky reads this, he will have the answer.
he was a Ford enginer working on these trans back in the day.
Charlie
Old Apr 6, 2023 | 09:21 AM
tecgod13's Avatar
tecgod13
Is the trailer 4 pin still hooked up? Unplug it and see if it goes back to normal. I'm guessing you have a short in the trailer wiring that is backfeeding to the truck and messing with the sensors.
Old Apr 6, 2023 | 11:50 AM
LukeTheDuke256
Trailering
unfortunately that was the first thing I had tried. I did notice that the wiring looked rough under the rear bumper for the trailer power hookup.
Old Apr 8, 2023 | 06:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
your next step is to check all fuses. if any are blown, check each wire connected to the trailer plug for short to ground or each other.
Kemicalburns
Nov 4, 2020 10:56 PM
gtadim
Apr 29, 2019 09:18 PM
AndysFords
Aug 3, 2015 04:34 PM
1wvboy
Mar 4, 2012 02:10 PM
deanj
Feb 14, 2005 02:58 PM
