damaged piston
Old Nov 16, 2003 | 11:29 PM
dual_rangers's Avatar
dual_rangers
damaged piston
I am rebuilding my 2.8l and have a damaged piston. I am wondering if I can replace just the damaged one, I have another engine for parts and I am also doing the rings and bearings, or does the whole set need to be replaced? also what is the best way to clean pistons. thanks in advance.
Old Nov 17, 2003 | 10:14 AM
f100guy's Avatar
f100guy
yes you can just do one piston. maybe soak them in diesel
Old Nov 17, 2003 | 10:32 PM
mdh627's Avatar
mdh627
you can replace one piston,but make sure you change the rings and bearings for that cylinder. You will need a ring groove cleaner to cut the carbon deposites in the ring lands
