1995 F150
Old Apr 5, 2023 | 11:17 AM
Biggpapa1968's Avatar
Biggpapa1968
4wd Low
1995 F150
I have a 1995 f-150. 6 cylinder standard transmission. I've been having trouble for a few months now. One day it won't start, let it sit a day or two and it starts and runs good. Then all of the sudden it won't start again. It has started acting like it wants to die as I'm driving it, but just once in awhile. It sat a lot before I bought it cause it was a company truck and only used maybe a few times a month. So today as I was going to work it just died and wouldn't restart. I was thinking either fuel pump relay, or just fuel pump issues. Does anyone have any suggestions or comments to help me out?? Anything would be appreciated.
Old Apr 5, 2023 | 05:42 PM
Franklin2's Avatar
Franklin2
Wrong forum, but when it will not run, I would get some flammable brake cleaner or ether and spray in the intake and then see if it will run on that. If it still won't run, you might have a ignition problem. Being a 95 you probably have the TFI ignition module. If it's mounted on the distributor, they had a lot of problems with those failing from the heat. If yours is remote mounted (they started doing that on the later years) you still might want to check for spark to see if that is why it will not start.
Biggpapa1968
Apr 5, 2023 09:37 PM
ryanj_610
Apr 26, 2022 03:28 PM
Theblue72
Feb 4, 2022 09:44 AM
nlassley
2009 - 2014 F150
17
Dec 28, 2021 08:59 AM
66 bronco roadster
Dec 31, 2020 04:04 PM
