2023+ TREMOR SD thread
Old Apr 5, 2023 | 08:40 AM
byz250f's Avatar
byz250f
Who has gotten there P708 Tremor super duty yet? Mine was built about a week ago, and I saw one at a dealer yesterday. Really trying to find out what changes made for 2023 around towing improvements. I heard Ford made the new Tremor more stable at towing vs prior gen.
Old Apr 5, 2023 | 09:46 AM
1olddogtwo's Avatar
1olddogtwo
I don't recall any towing stability issues with mine whatsoever. I don't recall any issues actually.
Anytime a vehicle is raised. The center of gravity is raised so inherently it's a little more unstable.
Old Apr 5, 2023 | 10:06 AM
byz250f's Avatar
byz250f
Did you have a F250 or F350, gas or Diesel? Were you towing bumper pull or 5th wheel? Sorry for so many questions trying to peg down the situation where people with tremors are having towing issues.
Old Apr 5, 2023 | 10:11 AM
1olddogtwo's Avatar
1olddogtwo
Ask all the questions anytime anywhere.
Mine was a 2020 with 6.7 F350
If I recall correctly, 250 and the 350 tremors have the same suspension in the rear as well as the front. Somebody will correct me if I'm wrong.
I hauled conventional and gooseneck, never a fifth wheel.
I've personal owned 17 super duties since 99. I thought it was a great truck but I get rid of trucks every year.
Old Apr 5, 2023 | 10:13 AM
CheeseheadFord's Avatar
CheeseheadFord
I don't own a tremor but don't recall reading here or in other forums any specific issues with Tremor's and towing. There are plenty pulling quite the load with their Tremors and doing so fine.
Old Apr 5, 2023 | 11:01 AM
byz250f's Avatar
byz250f
Good to hear, sounds like we have similar methods on truck ownership! Good to hear no issues...hoping no issue with my upcoming F350 towing as it will be replacing my 2021 Raptor that does good towing.
Old Apr 5, 2023 | 11:30 AM
CheeseheadFord
The 350 will be night and day if you're used to towing with a Raptor and think it does good towing....
Old Apr 5, 2023 | 11:57 AM
byz250f's Avatar
byz250f
Good to hear, I have owned 5 raptors and I still believe they are the best towing half tons on the market...the extra wide width, stiff frame, HD cooling, and axles. I have the new Airlift air bags for my 21 Raptor and its pretty decent towing our 33ft 8500lb travel trailer in 2022.
Old Apr 5, 2023 | 02:58 PM
CheeseheadFord
I've never driven a Raptor but this is exactly the opposite of what I've read and understood regarding towing with a Raptor, glad it's worked out for you though. I went from a 12 F150 5.0 to the truck in my sig, and pull a camper a bit longer than yours and a bit lighter and its a much better towing experience with my F250.
Old Apr 5, 2023 | 03:02 PM
byz250f's Avatar
byz250f
Its interesting I went from a 16 max tow F150 13k lb tow rating to a 17 Raptor 8k tow rating and the stability and sway was drastically better on the 17 raptor vs the 16 max tow. I experienced same thing when I borrowed my brothers 17 GMC 1500 Denalli 6.2. Raptors squat, but the wider stance really helps the stability I have found. Once you add air bags to them especially on the gen 3 its pretty darn solid. Im looking forward to seeing how this 23 Tremor F350 tows.
Old Apr 5, 2023 | 03:22 PM
1olddogtwo's Avatar
1olddogtwo
Similar indeed... 2020 Raptor, 20 Tremor, 21 Raptor and now a 22 Bronco Raptor
Old Apr 5, 2023 | 05:13 PM
DPelletier's Avatar
DPelletier
Lots is said and inferred about 2023 changes and "improvements" but I think the reality is that changes are relatively minor, mostly cosmetic and (outside from the new 6.8) have little to do with the frame, chassis or drivelines. For eg. at one point they talked about an "all new frame".....then "frame improvements" which then devolved into better attachments from the receiver to the frame......at this point I'm thinking new receiver bolts and maybe a bracket change.... LOL
Not knocking 2023's or Tremors; I'm sure you'll be very happy with your truck.
Dave
Old Apr 5, 2023 | 09:22 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Previously, the Tremors have lower tow ratings than the standard 250/350’s. Being that they somehow raised all the tow ratings for the 23’s without any actual changes, the Tremors most likely saw an increase in ratings too.
Old Apr 7, 2023 | 08:36 AM
byz250f's Avatar
byz250f
most of the 23 Tremor F350 HO diesels Im seeing are having 400-500lbs more payload then the 2022 model year.
Old Apr 7, 2023 | 11:00 AM
4wd6.7L's Avatar
4wd6.7L
Payload yes, they don't have a reduced GVWR so payload is not limited, but the tow ratings were lower than a comparable non Tremor.
Payloads are up because GVWR's are up.
BRIANSC6
Ontario Chapter
May 18, 2022 10:53 AM
Ron94150
6.2L V8
41
Nov 15, 2018 04:31 PM
derek4343
Feb 24, 2017 04:14 PM
4dogdoc
Sep 26, 2016 09:05 AM
kjf-250
6.7L Power Stroke Diesel
Feb 4, 2011 08:37 AM
