Best OBS 02 sensor
Old Apr 4, 2023 | 05:44 AM
yeet's Avatar
yeet
Best OBS 02 sensor
What brand are you guys using when replacing the 02 sensor on the OBS trucks. I've always used Bosch in the past on other vehicles. What was the OEM supplier for Ford back in the day?
Old Apr 4, 2023 | 08:36 AM
jas88's Avatar
jas88
I believe it was Bosch.
Old Apr 4, 2023 | 09:53 AM
OBS4ever's Avatar
OBS4ever
I recently replaced my old O2 sensor with a Bosch and it has worked great.
Old Apr 4, 2023 | 10:07 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I have seen threads where that is what came on the “OBS” trucks. My ‘87 and ‘89 had a NTK oxygen sensor.
Old Apr 4, 2023 | 01:52 PM
yeet's Avatar
yeet
Ok, Bosch it is then. Thanks Guys
Old Apr 4, 2023 | 03:32 PM
OBS4ever's Avatar
OBS4ever
You're welcome.
Old Apr 4, 2023 | 03:55 PM
Mo8414's Avatar
Mo8414
About 20 years ago I needed a 02 sensor for my 92 cavalier. Went thru 3 bosch that were bad out the box. Ended up having to find one that was a different brand for it to work. The mechanic could see if they were working with his computer. Maybe it was a fluke but ill never buy another bosch 02 sensor again.
Old Apr 4, 2023 | 11:16 PM
Ronniewhite's Avatar
Ronniewhite
I wish I had of asked this. I just got one a couple weeks ago, a denso. I haven't got it in yet. I've been soaking the old one in pb blaster, she's seized.
Old Apr 5, 2023 | 06:16 AM
yeet's Avatar
yeet
Same here. I've been soaking mine as well. 123,000 mile original sensor. Let the games begin this weekend. Good luck Ronnie!
Old Apr 5, 2023 | 09:58 AM
sswari's Avatar
sswari
Warm it up a bit, and then smack it a bit, work it back and forth is you get any movement. Heat is also your friend.
Old Apr 5, 2023 | 02:45 PM
Ronniewhite
ya we tried that for 45min. We did get it too move a little bit. I'm going to keep soaking it for a while and try again.
Old Apr 5, 2023 | 04:40 PM
blazerman07's Avatar
blazerman07
I went with the Bosch and used penetrant and this wrench instead of my O2 socket.
Old Apr 5, 2023 | 05:44 PM
yeet's Avatar
yeet
A couple guys I spoke with said to use the 7/8 socket with a metal screw type hose clamp around it to keep it from spreading due to the slot for the wires. I have about every kind of socket and wrenches possible so I have multiple directions of attack. Have a new bottle of Mapp gas on hand as well for heating it.
If all that fails Ebay has a whole new Y pipe with a new converter for under $250.
Every 10 minute job is one broken or stuck bolt away from being a 3 day $500 ordeal.
Old Apr 5, 2023 | 07:21 PM
Ronniewhite
we had the 02 socket on then a piece of pipe on the ratchet handle and were only able to get it to move a little. She's probably been in there 28yrs.
Old Apr 5, 2023 | 07:25 PM
blazerman07
same here. I plugged it back in and ordered this cause I just couldn't get the leverage, but with the offset it dropped down enough, put my 18" pipe on it and turned easily.
Iantiler
Feb 8, 2023 06:02 PM
JOHN2001
Aug 9, 2012 09:21 PM
400 .040over
Electrical Systems/Wiring
May 5, 2012 09:10 AM
