86 E350 460 Fuel return valve
Old Feb 20, 2004 | 05:52 AM
tdbudman's Avatar
tdbudman
It's called a "fuel vapor separator". I believe the stock size is .0090. The .0090 is the size of the return line. Ford then designed smaller return orifices to solve fuel starvation problems. The other sizes available to date are .0060, and .0040. I'd go with the .0040. I can get u the part number later...out of time right now. Your Ford dealer should be able to find it under that name, around $36.00. Napa carries them as well for a lot less.
Old Feb 20, 2004 | 01:42 PM
glennkunsman's Avatar
glennkunsman
thanks for the info - appreciate the fast turn around!!!! If you find yourself just staring at you truck with a few minutes to spare a part number would be greatly appreciated.
I have a 1986 F350 (460 cid) soon to be flat bed with all the emissions riped out. I have finally found most of the non-electrical smog gear - it is a serious task. fuel system is the final bit....
Again thanks.
Old Feb 21, 2004 | 07:22 AM
tdbudman's Avatar
tdbudman
EDTZ-9N176-D....Valve Asy Fuel. I believe that's the number for the .0090. I suggest the .0040. Good luck
Old Feb 21, 2004 | 12:55 PM
glennkunsman
Thanks for the info - I really appreciate it!
Old Feb 25, 2004 | 12:03 AM
archangel's Avatar
archangel
I made one from brass fittings with a .040, that's fourty thousands, not four thousandths as mine was missing!
It works great as I have 4.5 psi fuel pressure and a glass filter in line with a fuel pressure guage before it on the drivers fender and it has no restriction other than that tiny return line hole!
Old Feb 25, 2004 | 12:42 PM
spikedog's Avatar
spikedog
I've got one of those little buggers in my "82 E350 land yacht. I went through last summer thinking that it was my rough hot idle problem (turned out to be vacuum lines). Of course it looks just like a fuel filter, so I yanked it out and tore it open. Then I had to buy a new one......
It was put in these vans since a great portion of E350's are used as commercial service vehicles. I guess Ford's thought was that these rigs would spend alot of time just idling, so they put in "hot fuel recirculation" (8Lugs makes mention of this in an earlier post) so that they wouldn't vapor lock.
It does seem like an unneccesary complication to the fuel system that is already complex if you have dual tanks. I guess vapor lock was enough of a problem for Ford to come up with this do-dad.
Old Feb 27, 2004 | 05:15 AM
tdbudman's Avatar
tdbudman
Engineers.......buy em books, dress em up and send em to school. Look what you get. A do dad.
Old Feb 27, 2004 | 03:13 PM
archangel's Avatar
archangel
But a useful do dad!
Old Jun 4, 2006 | 05:24 PM
aldog's Avatar
aldog
Same problem haven't figured out how to fix it yet part # E3TZ 9N176 B for 0.40 size
quakerj
Nov 1, 2016 06:37 AM
Cjpower9185
Dec 22, 2015 10:47 PM
KRinAZ
May 19, 2014 11:58 AM
KIKKUP
31
Sep 12, 2013 09:23 AM
JoeVR5
Jul 4, 2008 07:47 AM
