I am rebuilding my 95 F250 for a bit more power to pull my 5th wheel. I'm almost done getting all the parts for my transmission rebuild. The problem I seem to be having is finding the fittings so I can install larger transmission cooler lines. The stock lines I guess are 5/16 and some of the diesels used 3/8th. I understand that the 4R100's are more likely to have 3/8th but most of them have the bypass tube.
Does anyone have a part number or a source where I can buy these fittings. I understand that there is a check valve in the rear fitting. Even used ones would be a solution. If there are 1/2 line fittings, I may even look into that.
